Cold starting on 50 series
Bob67
12-12-2005 03:56:06
Having some problems to start my JD4850 during cold weather (i.e. under 0 degrees Celsius) I carried out the usual checks and came to change all 6 injector nozzles as those were in poor condition. This had slightly improved the starting but still, it is not perfect. When I checked the JD Technical Manual I noticed that the 4850 has a lower compression ratio than the 4650 and also the 4850 has 6 holes in the nozzles (only 4 on the 4650). Having read this, I am just wondering if all 4850s are harder to start than any other models of this series. A colleague of mine who also owns a 4850 stated that he has the same problems. Can anyone confirm that all the 4850s need ether injection to start when wheather is cold ?
ricedaddy
12-13-2005 17:27:01
 Re: Cold starting on 50 series in reply to Bob67, 12-12-2005 03:56:06
agrees with G/Man. I start mine at well below 0, with just the block heater! Best money I ever spent for winter starting!
G/MAN
12-12-2005 07:16:36
The lower mechanical compression ratio means that good overall engine condition is more important to good starting. That said, even in perfect shape, a 4850 probably isn't going to crack off too well at freezing or below. Have you tried plugging it in? Just because a certain engine WILL start unaided at certain temps doesn't mean it SHOULD. A good block heater and semi-warm coolant at start-up will save a bunch of wear.
buickanddeere
12-12-2005 04:03:08
What is the voltage before, during and after cranking? Measured from the starter's cast body and the large copper post geing into the starter? Is there a hydraulic pump de-stroker on there?
Bob67
12-12-2005 04:06:11
 Re: Cold starting on 50 series in reply to buickanddeere, 12-12-2005 04:03:08
Batteries are new and starter motor has been checked.
buickanddeere
12-12-2005 15:05:08
 Re: Cold starting on 50 series in reply to Bob67, 12-12-2005 04:06:11
What is the voltage? New batteries and checking the starter motor is just a guessing shot gun approach at trouble shooting.
