Steering / Starting Wheel
Joe M(GA)
12-10-2005 18:51:25
Help me out guys,look at the photo in the "parts & Pieces" and tell me what I"ve ended up with, and what model is it from?
donmyeil
12-11-2005 14:16:28
 Re: Steering / Starting Wheel in reply to Joe M(GA), 12-10-2005 18:51:25
I bought one from Deere a 4-5 years ago. I welded a socket on and cut the cam out of it. makes an excelant tool to turn the engine over and back up if you want to.
CLW
12-10-2005 19:18:04
Well Joe it looks like it is an adapter to hand start a tractor. It is not the one used for the early styled A,B or G as they were solid. I have not seen what the ones for the late styled or numbered series used. In fact I have not heard of anyone useing one on the enclosed flywheel, but I think it can be done.
CLW
Walt in Jaxn Tn.
12-10-2005 19:53:04
 Re: Steering / Starting Wheel in reply to CLW, 12-10-2005 19:18:04
Joe, that's for Late 1947 A,B, and up and also 50, 60, and I believe 70, Mabey 520 thru 730 also. --Walt--
Joe M(GA)
12-11-2005 05:37:22
 Re: Steering / Starting Wheel in reply to Walt in Jaxn Tn., 12-10-2005 19:53:04
Thanks guys, is this rare? As in do I need to put it up? Or are they everywhere. Thanks for the help, I'm still learning my older Green.
CLW
12-11-2005 08:31:04
 Re: Steering / Starting Wheel in reply to Joe M(GA), 12-11-2005 05:37:22
I guess it is somewhat rare as it is the first one I have seen. On the other hand if they were in great demand I would have seen one I guess. Most folks that could not start there tractor with the starter would pull it if they have a way. I don't think it will bring more than a couple bucks if you found someone who wanted one. I would put it on a shelf and may find a use, or buyer for it someday.
CLW
