Help me with my 4320!!!!!!!!
Chucky
12-10-2005 09:01:13
My 4320 is driving me nuts!!!!! !!! I can't seem to find what is causing the noise in my transmission. Sometimes it will make a "rattling"noise like a bearing is going out the you can change gear to any other gear and it will go away. Then the nextime you get on the tractor it will make a noise in a differant gear but not the gear that it made the last time you drove it. Today it was making the noise in 7th the last time it was 5th and so on. There was absolutly no noise in 6th or 8th and so on.
I have replaced the top shaft bearings, updated the syronizor to the new stlye, checked the rest of the bearings and gears and everything looks good and turns over smooth by hand with no noise, drag, or catching.
Also today I had it jacked in the air trying to narrow it down and on of the times that I "drove" the tractor in the air it made the sound, then I placed the trans in neutral and as soon as I took my foot off of the clutch it made the noise. The rest of the time it did not make any noise ever if I placed it back in the same gear and placed it in neutal again.
I have talked to Deere mech. have an uncle that has worked for the Deere dealer for 20 years had it split apart twice and still the same noise. I'm at wits end and far from driveing the tractor until something breaks so I know what to fix I don't know what to do.
Any help will be appreciated. Thanks Chuck
chucky
12-11-2005 20:23:55
 Re: Help me with my 4320!!!!!!!! in reply to Chucky, 12-10-2005 09:01:13
I hope we got it figured out. The best we can figure is that the previous owner ran the tran/hydro oil dangerously low or out while using the pto end in 4th gear causing the case harding on the pto gear witch we replaced and I beleive the 4th- 7th combo or 2nd- 5th gear because they are next to one an other and when the tractor is placed in 4th 7th gear the beval cut gears will cause the gear to shift and the shift collar is ratteling against the opposite gear. The only way we will know for sure is to take the bottom shaft out and that sounds like a lot of work.
thanks Chuck
Glen in TX
12-11-2005 09:24:51
I was thinking same thing about checking your clutch again. Bad clutch or bearing will send noise through the drive train. If it has been split twice and not found someone sure failed there. What kind of maintainance was done on it before you got it? Check the trans/hyd filter and pull the inner pump sump screen out of the plug on side of trans if that hasn't been done and check for foreign matter from a bad bearing or brake material. Yes, the trans had to be drained to pull the screen. Many have never cleaned that screen like it should be done when changing trans/hyd fluid and filter. There is also a screen in the front pump too.
jason s
12-10-2005 23:13:18
Sounds like the throwout bearing in my car.
Roger in Iowa
12-10-2005 13:32:59
There is a pump in the transmission that feeds oil to the main pump under the radiator. The transmission pump is not "live". When you depress the clutch pedal it stops. I believe it is making the noise. My 3020 does it all the time and has for 15 years. I am surprised the fellow with JD experience would not know about this...
When you start it up. Keep the clutch pedal depressed and raise and lower the 3 point until it will not operate. Lower the three point. Engage the clutch. You should hear the main pump at the radiator work for a bit and then quit. What happens to the noise? It may happen when the main pump is working or it may happen when the main pump quits working.
I don't believe you have a problem???
Roger in Iowa
