4010 compression
chris .r
12-09-2005 16:31:16
I have a john deere 4010 that seems to have a hard time pulling a 3-16 plow and it puts out a big cloud of smoke once it gets a load. That my 2630 pulls no problem. I did a compression test on it and i got 300P.S.I the i&t book says it should be 450-475 in all cylinders. I took the head out and one piston out and i could nt find any thing wrong. the Liner still had the cross hatch pattern on it it was only rebuilt about 500 hours ago. the only thing was the pistons had a little bit of slop in it. Should they be tight or is it normal to be able to wiggle them slightly. any ideas?
Al Epp
12-11-2005 04:59:00
 Re: 4010 compression in reply to chris .r, 12-09-2005 16:31:16
I used to have a 4010 gas that I pulled 4-14s with. Pulled them in 5th.Would lose some rpm in the clay spots but would keep on going.This was in soybean ground though, I'm sure things would have been different in sod.I now have a 4020D and 5-16s.Pull them in 3rd and 4th. Your tractor shouldn't even know 3-16s are behind it,especially if it has the 4020 kit in it.
chris .r
12-12-2005 15:39:09
 Re: 4010 compression in reply to Al Epp , 12-11-2005 04:59:00
i completely agree with you Al all the farmers here pulled their 3-16 rollovers behind their 4020's like their was nothing behind it and this 4010 does have the 4020 sleeve kit in it. I have to put it in third gear untill the smoke clears out and the tractor does nt feel like its working to hard. When I get this tractor figuired out i will leave a post if anyone cares but thanks for for your help so far.
4010guy
12-09-2005 18:27:30
i would think a 3--16 would be a full load for a 4010---but it depends on soil typ and how deep u plow ofcorse---valves inj.pump and maybe injecters are always good place to start
J. Schwiebert
12-09-2005 17:23:25
Have you checked pump timing? Since you have the head off have you checked valve recession? How does it start? Have you put it on the dynometer. My cousin had a 4020 that did not pull good either. Once we changed all the filters and did a good tuneup we picked up over 15 Horsepower.
chris r.
12-09-2005 17:39:52
 Re: 4010 compression in reply to J. Schwiebert, 12-09-2005 17:23:25
i have checked the pump tming and at seven degrees before tdc it was dead on im not sure if that is the correct timing for it now that it has the bigger sleeves installed. It starts real good and it does nt put out white smoke like you would see with low compression normally. I would like to put it on the dyno but my local dealer wants 150 bucks to test it so i passed. i have not checked the valve recession, will tommarow i just checked the clearance on valves wich were right. also the intake valve ports seemed to have a sheen of oil on them does that mean anything in particular.
DONMYEIL
12-10-2005 12:25:31
 Re: 4010 compression in reply to chris r., 12-09-2005 17:39:52
If the pump has the speed advance conversion the timing would be 8* before tdc. the advance should be 6* at wide open throttle. If the pump has not been converted the timing is 14* btc. Also, has the 3point hitch sensitivity been adjusted and set in l&d position? if these things are not right it will kill the tractor for power. Is there enough front weight to make the hitch work ? Should have base weight and one weight for each bottom. should pull that plow in 4th gear anywhere. just some thoughts
J. Schwiebert
12-09-2005 18:46:27
Depends on how you look at it. The engine pulls good vacuum and is pulling a little oil past the guides or the guides to valve clearance is on the high side. When I did the machine shop work we put some Perfect Circle seals on a few of them. What do other dealers or independent shops charge for a dyno test?
