3010 Rough Engine Hydraulic Question
Charles Beavers
12-09-2005 11:28:51
I have two problems with my 1961 JD Gas 3010:
First problem: The engine seems to run OK until it heats up to about 140 degrees. Once it heats up the engine will start running rough either in idle or with a load. I installed new plugs and wires (plugs seem to carbon up fast), points, rotor and distributor cap. Also, the carbuetor was recently rebuilt but the problem still persists...any suggestions!!
Second situation: My hydraulic pump has a bleeder fitting on the bottom. I understand this fitting needs piped back to the transmission in order to reclaim the dripping hydraulic oil. Can anyone discribe to me exactly were this fitting should be piped to. The only thing I see going to the transmission is a very small line from the brake foot plungers piped over to the transmission. Does the hydraulic bleed line get tee'd into this line somehow??
Your help will be greatly appreciated.
Thanks...Charles
Charles Beaverson
12-10-2005 10:11:14
 Re: 3010 Rough Engine Hydraulic Question in reply to Charles Beaverson, 12-09-2005 11:28:51
Update to Rough Engine Problem:
I just went out and replaced the 4 spark plugs with new autolite #386 and now the engine runs smooth. I seem to be replacing spark plugs very frequently due to carbon buildup (I've always used autolite #386). Is this the same situation that I've seen other posts recommending changing to electronic ignition?
Thanks...Charles
tro
12-09-2005 17:05:30
As for the engine check the compression. It may need a vave job. I worked with one some years back after it was sold the guy did a valve job no more problems.
Charles Beaverson
12-10-2005 06:33:32
 Re: 3010 Rough Engine Hydraulic Question in reply to tro, 12-09-2005 17:05:30
Tro,
Thanks for your reply! The tractor does seem ok for about 30 to 40 minutes after start up. I have seen other posts where electronic ignition has been recommend for plug fouling and engine running rough for this series of JD tractor. Valve job has faintly crossed my mind, but I am hoping it is a more simple fix.
Thanks again...Charles
