How often to change oil for parade tractors
RonT in TX
12-09-2005 09:54:58
I have a 1936 BN and a 1949 B that are driven around 1 mile about every 10 days. Both have not been worked since being restored. How often should the crankcase oil be changed? Also, how often should the transmission oil be changed?
JGC
12-09-2005 12:24:17
 Re: How often to change oil for parade tractors in reply to RonT in TX, 12-09-2005 09:54:58
I have a "D" that runs about 30 hours max per year. I change the engine oil in the fall before "winterizing" the tractor. I make sure that I open both of the engine drain plugs and always change the filter.
I drain a small amount of oil out of both transmission/differential plugs to check for water AND for metal bits. On my "D" there is a drain plug in the main case below the PTO drive gears. I should - but have not cracked it open to check for water. I will not change the trans/diff oil for 5 years.
I have a magnet that I pass thru the drained engine oil to check for metal bits.
Ebbsspeed
12-09-2005 11:32:16
I change the engine oil in mine once each year, just before putting it away for the winter. I do work mine about 6-10 hours per year on a mower, the rest of the time (another 6-10 hours) is just putzing around pulling the hayrack for rides, etc.
Transmission, I crack loose the plug just enough to let any accumulated water drain out at the end of each season, same time I change the engine oil. Note that you have to do this after the tractor has set for a few days, to let the water settle to the bottom of the transmission case. I don't really keep track of how often I change the transmission oil, but it probably averages once every 5-6 years. Some of these old tractors that were worked hard went lots of years between transmission oil changes. When I first got my "B" I pulled the transmission plugs out and nothing drained out. There was a layer of solid gludge (gunk + sludge) about 2 inches deep that I had to poke a screwdriver through to get the oil to drain out. And I use the term "oil" loosely because the stuff that ran out was hardly recognizable as any kind of lubricant.
