Compression test / Valve leak test
Jason Z in MO
12-09-2005 07:38:17
1940 B SN 81291
THought I would ask the question on this board too.
Right now I have the rebuilt head installed on the .045" over block with .045" over pistons and new rings. The rocker arms are not installed. I thought I would check the compression so I installed a pair of plugs and the compression release valves. Slipped the flywheel on the crankshaft and put duct tape over the intake and exhaust ports on the head (manifold not installed).
Pulling #1 up to TDC the intake valve was leaking quite a bit. With just a slow rotation I could easily blow the tape off the intake port. The exhaust valve did leak quite a bit too. During this test, I had #2 plug removed so it would not affect the test.
Next I checked #2. The leakage wasn"t near as bad and I could hear most of the air leaking around the rings. It did "bubble" the tape up but not blow it off like #1.
My question: is this acceptable for fresh valves and seats?
If it"s not acceptable, I would suspect the seats or springs. I had the head done by a local machine shop with a decent reputation.
Sorry for another long post...
Jason Z in MO
12-09-2005 17:24:22
 Re: Compression test / Valve leak test in reply to Jason Z in MO, 12-09-2005 07:38:17
The latest...
Per suggestion from FIT. I took an old crappy TT-10 plug and removed the core. The remaining hole was perfect for a pipe thread tap so I tapped the hole and screwed in an air quick adaptor. Now I can pressurize the cylinder.
With regulator set at 80 psi: #1 exhaust leaking alot; intake slightly. I can't seal the air with my hand over the port.
#2 exhaust leaking but not as much as #1; intake slighty.
I tapped on the valve stems with a rubber mallet but not while under pressure. This might have helped #1 slightly. I was chicken to do it while under pressure knowing the air pressure combined with the valve spring would slam the valve pretty hard.
So should their be any leaking at all? I assume no. Will there be too much stress on the valve and seat to tap on it while under pressure?
I didn't try 100 psi because they wouldn't hold 80.
Bob
12-09-2005 18:24:04
 Re: Compression test / Valve leak test in reply to Jason Z in MO, 12-09-2005 17:24:22
You ain't gonna hurt them with 100 psi air.
Think of what they open against when the engine is firing under load!
JGC
12-09-2005 12:50:41
I have only rebuilt one "D" engine so I am not an expert. I am surprised that you are getting any amount of leakage. If the work was done properly, the valves should seal tight. It could be dirt on the sealing surfaces. If the rebuilder used valve grinding compound or valve 'lapping' compound there could be specks of the abrasive holding the valve open slightly!
I have tested valve condition before by applying compressed air at low pressure (about 10 psi) thru the spark plug hole and listening at the carb and exhaust stack for the sound of air leaking.
Let us know what you find out!
Jon
Jason Z in MO
12-09-2005 13:54:46
 Re: Compression test / Valve leak test in reply to JGC, 12-09-2005 12:50:41
Thanks all!
I will try the suggestions mentioned. I did press the valves open with the palm of my hand but didn't let them snap back shut. I will tap on them with a mallet and see if that helps.
I have done some rebuilds in the past but never did a test like this.
I did call the machine shop today and they were surprised. They said they check each head when it leaves that it will hold 18 inches of vacuum.
I will keep you posted!
Jason Z in MO
12-09-2005 13:54:40
Thanks all!
Mike M
12-10-2005 05:31:26
 Re: Compression test / Valve leak test in reply to Jason Z in MO, 12-09-2005 13:54:40
Even good shops if mainly automotive shops don't have stones big enough to do 2 cyl. JD's and I highly doubt they built a special fixture big enough to test a tractor head even if they do check all the car heads. You just never know ? I ran into this one time someone brought me an A head to tear apart and inspect after he had just had it done. His suspicions were right as the intake seats were not ground. I suspected they didn't have stones big enough. I had a real hard time finding extra NEW stones big enough. I think most of the supliers stop at 2 1/2" or whatever cars stop at.
Jason Z in MO
12-10-2005 07:10:09
 Re: Compression test / Valve leak test in reply to Mike M, 12-10-2005 05:31:26
Mike,
I'm going to pull the head this morning and probably take it back. First I'll take out a couple of valves to see how they look. I just assumed they did a good job. Those B valves aren't that big, I sure hope they ground the seats!
Mike M
12-10-2005 11:13:21
 Re: Compression test / Valve leak test in reply to Jason Z in MO, 12-10-2005 07:10:09
Before I"d pull the head I"d give all the valves a good quick crack on the end of the stem with a hammer and let them slam shut a few times and see if it helps.
Earl-IL
12-10-2005 10:14:05
Jason, I have been reading the post and I would not only agree ,but tell you that the head needs to come off.I owned and operated a Automotive -Industrial Machine Shop for 30 yrs.I am retired, but I do a lot of antique tractor engines rebuilds, carbs, & mags.The small "B" valves should not be a problem for any good shop.#1 were the guides replaced? What happens is most shops now use a tri cut system ,which is (EXCELLENT).But if the guides are loose which I suspect they are. The tri cut will cut a beautiful (OUT OF ROUND SEAT)# 2 the antique tractors don't run the (CLOSED VALVE SPRING SEAT PRESSURE) that a higher speed engine does . I always hand lap the valves and clean the valve & seat by lapping with oil to remove all of the abrasive from the lapping compound. I grind the seat at 45 deg. and the valve at 44.5 deg or 30 deg seat and 29.5 valve The width of the seat will depend on if it is a working tractor or a parade tractor.I run the seats a little wider on the working tractor. Replace or shim the valve springs to factory specs.Clean the head with hot soapy water then blow dry spray with WD 40. Lube your valves & guides. You must remember how old and how many times this spring has been hot and cold.If the valve seats are too deep in the head I cut them out and replace them.You have to use a good quality seat to keep them from coming loose.I can recommend if anybody need brand names & sources.When I get done with a 2 cyl deere head you can set the head up like it goes on the tractor and fill the intake & ex ports with solvent and it won't leak out in 24hrs.Valve guides and springs are over looked many times because most shops don't know where to look for parts.Many times I have had guys tell me well its a old engine they don't run much it will be better than it was. That is not why we tear them down. There isn't any reason they can't be repaired correctly.The vacuum test they use on those machines is not the answer. Run the pump up then shut it off, it will not hold 18 lbs if the valve is leaking.We want these old tractors to run & (idle perfect) you have to have everything right. Sorry for the long post. But this is what you need to do to fix your tractor. Earl In Illinois
jd b puller
12-10-2005 12:15:56
 Re: Compression test / Valve leak test in reply to Earl-IL, 12-10-2005 10:14:05
Jason/Earl:
The last two (B) heads I have had done I took them to two different shops. Both of them required a special tool that I had made. It is 7/16" diameter on one end and 3/8" on the other. They used this to cut the seats. The 7/16" end goes in the valve guides and the 3/8" end goes in their machine.
Earl -IL
12-10-2005 15:11:24
 Re: Compression test / Valve leak test in reply to jd b puller, 12-10-2005 12:15:56
JD-B puller, There are 2 basic types of pilot set up for tricut machine. The wedge type or expanding pilot like you use on a seat grinder. The Serdi uses a rotating pilot. Both setup require near perfect valve guide.Where do you pull? I have done a lot of pulling modifications.Earl
jd b puller
12-10-2005 17:54:14
 Re: Compression test / Valve leak test in reply to Earl -IL, 12-10-2005 15:11:24
Earl: I"ll be pulling in NC this year. Been out of it for 2 years for some crazy reasons... These southern boys have some crazy rules - seems like there"s division II and Division V, but nothing in between. Mine is clearly a Div III tractor, so I either need to find a set of 13.6-38"s that aren"t cut or make more HP. I suspect tires are cheaper than HP, but I have been trying for 6 months to find a decent set of 13.6s. You almost trip over 15.5-38"s but you can"t run them.
Earl - IL
12-10-2005 18:43:10
 Re: Compression test / Valve leak test in reply to jd b puller, 12-10-2005 17:54:14
Get all the 15.5-38 F&R you can and bring them to Illinois for trading material. Earl
Jason Z in MO
12-10-2005 11:12:54
Earl,
Thank you for your comments. I pulled the head and removed the intake and exhaust valve for #1. Visually looking, the valves look good but the seats look to have poor machining. I'll go back to the shop and take some measurements. I don't think I want to take it back to the shop who did the original work. I have a lot of time and money invested. I know its just a run of the mill B but like you said I do want this thing to run as perfect as possible. I have invested a lot not to end up with it to run sub-par, especially for a hand starter.
I might be interested in your services. Where in IL are you located? I work in St. Louis.
Earl IL
12-10-2005 15:03:02
 Re: Compression test / Valve leak test in reply to Jason Z in MO, 12-10-2005 11:12:54
Jason, I live 9mi west of Champaign on I74 little town Mahomet,IL. I have done some mag work for Jerry Wallen in Farmington ,Mo. Did the valve seats have chatter marks. Good luck. Earl
Jason Z in MO
12-10-2005 16:27:07
 Re: Compression test / Valve leak test in reply to Earl IL, 12-10-2005 15:03:02
Earl,
Well, I removed the valves and did some inspecting. I measured the stems. They are all between .371-.372". They are within a thousandths or two over the length I can't find any signs of wear except some very small pits from rust. I don't have a way to measure the ID of the guides but #1 Exhaust is the worst. Using a dial indicator it has .004" side movement or slop. Using my make shift valve spring tester, I get between 33-34 LB at 2 13/16". Intake and exhaust valves are both cut at 45 deg.
I don't know what the correct measurements should be my service manual SM-2004 doesn't cover my SN.
The seats I believe are the whole problem. Not at all uniform and sections still have rust pits on the face. The face of the seats are around 1/16" wide. Seem kinda narrow. I took a bunch of pictures but I don't know if you will be able to see much.
How do I contact you? You can email me at [email protected] or 636-448-2608
I need this done right.
Earl -IL
12-10-2005 19:01:44
 Re: Compression test / Valve leak test in reply to Jason Z in MO, 12-10-2005 16:27:07
I think if you get the seats done right you will be Ok. I like 3/32 width on those intake seats and a little wider on the exhaust. Have you blued the seat & valve or tried a little compound to see if they (seats) are concentric. My email is ope,but I am going to be out of town until tues. morn. Earl
Mike M
12-09-2005 07:51:18
I think this rings a bell ? I think I had this happen to me years ago. Just a little bit of the prelube on the valves made them leak,try taping on the valve stems to let the valves slam shut and seat then retry. You may also need to remove the tape and hook up the rocker arms and check it with a compression gauge for real before you get too excited. I think you will find it is OK.
Bob
12-09-2005 07:49:58
Assuming a good job was done on the valves and seats, if the slightest amount of dirt or debris has fallen down the ports, and is stuck to oil or grease on the valve face/seat you will have leakage.
I believe I'd put the manifold on, and fire it up, and put some time on it, and then check again.
(And, obviously check your valve clearances.)
