1st time starter rebuild..Where to get parts?
Randy G.
12-09-2005 06:14:47
I"m about to rebuild my first JD starter off a 1941 B. Where can I get parts? Is there a manual I should get? Any tips or suggestions would also be of great value. I"m just doing this project as a learning experience to do in the basement. Any help will be very helpful!1 Thanks, Randy
John VB
12-10-2005 05:31:10
 Re: 1st time starter rebuild..Where to get parts? in reply to Randy G., 12-09-2005 06:14:47
I rebuilt my 620 starter last winter. Wouldn't even turn over once when it got cold. JD had the bushings and switch. Didn't need brushes. The bushings were bone dry and worn. The switch was severely pitted. One bushing that JD said was the proper one (changed part number) would not fit and had to be reamed. The starter turned it over like crazy after I finished. You should at least have a parts book to see how it all goes together if you forget.
G/MAN
12-09-2005 07:22:47
John Deere Service Manual #SM-2029 covers two-cylinder electrical systems, including component overhaul and testing, test specs such as free speed, amp draw, etc. If you want to do it "right", you'll want to have the commutator turned and the mica undercut if the commutator is badly worn, have the armature checked for shorts and opens, etc. Check your local yellow pages and see if there are any automotive electrical rebuild shops in your area. A good shop operator will probably help you with your rebuild if you throw him some parts business and let him do the commutator and so forth. Some guys take them apart, emery-cloth (NOT recommended) the commutator, slap new brushes in and call it good. If you're doing it for a learning experience, you may as well learn to do it right. That sort of work is fun - not too big and heavy and you can toss it on the bench.
Mike M
12-09-2005 07:57:35
 Re: 1st time starter rebuild..Where to get parts? in reply to G/MAN, 12-09-2005 07:22:47
"That sort of work is fun" ??? I guess sort of ,if done every once in awhile,but try doing it all day everyday for a living and it gets OLD fast. Especially those big nasty dirty diesel truck starters. Been there done that !!!! Not to mention those oil field guys that bring in a box full of magnetos and need them back at the end of the day.
G/MAN
12-09-2005 08:53:05
 Re: 1st time starter rebuild..Where to get parts? in reply to Mike M, 12-09-2005 07:57:35
"Fun" compared to replacing the final-drive on a combine in the middle of a corn field. "Fun" compared to replacing the high-pressure hydraulic valve running from the main hydraulic pump to the stack valve on an 8000-series tractor. "Fun" compared to replacing nozzles in an irrigation power-unit in the middle of a cornfield in mid-August when it's 100 degrees with 90% humidity.
Pete/ME
12-10-2005 04:27:38
 Re: 1st time starter rebuild..Where to get parts? in reply to G/MAN, 12-09-2005 08:53:05
Or how about breaking a track to pull the final drive in the middle of a half frozen spring when it's five below and a half mile back into the woods. I built a barn for repair work...the bench is right close to wood stove. I'd take the starter to a starter guy, he'll tell you what it needs, maybe just bushings.
G/MAN
12-12-2005 07:21:41
 Re: 1st time starter rebuild..Where to get parts? in reply to Pete/ME, 12-10-2005 04:27:38
I didn't do much undercarriage work in the country, but I did the Caterpillar thing for a while, and doing U/C work is about as hard as anything I've ever done. Pressing apart rails to turn pins and bushings, throwing pads, swapping idlers and rollers, etc.
Mike M
12-09-2005 10:57:48
That's for sure ,service calls rarely go smoothly. When I was doing my own repair business I usually made service calls with the truck and trailer and loaded it up and back to the shop we went. Of course I didn't work on those monster tractors and combines you guys always had out west and we see here more and more now.
Bob
12-09-2005 07:18:49
If there's a partsman at your local Deere dealer willing to dig out an old paper paertsbook, and look up the part numbers for the brushes and bushings, there's a good chance they are still available from Deere.
I have a couple of places to try to look them up, if you'd like to post the tag numbers off of the starter.
G/MAN
12-09-2005 07:24:08
 Re: 1st time starter rebuild..Where to get parts? in reply to Bob, 12-09-2005 07:18:49
You're right, Bob. A lot of the parts are still available from Deere - brushes, brush springs, etc. Some of the more exotic pieces are no longer available, though.
Mike M
12-09-2005 06:26:12
I have gotten some brushes and bushings from NAPA before. Just real hard to find someone to find it in a book. Try to find a local rebuild shop they should sell you parts.
