4020D Running Rough
Fudpucker
12-09-2005 05:06:35
I have a 4020D that was leaking hydro fluid. You guys helped me fix that. Now the old tractor is running really rough. It starts fine, idles fine, and will run up rpm good if you are sitting still. If you take off or star up a grade it really drags down. It will still go, but it is just rough. The tractor has fuel additive due to the cooler temperature. The exhaust seems to have a white/gray tint to it when you run it up hard. I am going to replace the fuel filter today, it looked pretty bad. I do not believe that there is any water in the fuel. Any thoughts would be appreciated as I would like to fix this myself, if I can. A couple of my friends say its the injector pump. any ideas? Thanks in advance.
JD9295
12-10-2005 00:53:10
 Re: 4020D Running Rough in reply to Fudpucker, 12-09-2005 05:06:35
FUEL FILTER
tro
12-09-2005 17:29:26
Is the screen under the air intake? If not check to see the air tube is clear I had one with a bird nest in it with same problem.
Spoker
12-09-2005 09:18:12
Checking the fuel filter and fuel supply is one of the first things I would check. I have had one that the valve train was not set right and caused this type of problem. I readjusted the valves and it ran better. Another thing you might check is start the engine, and let it warm up. Then crack the injector lines one at a time and see if there is a change in the engine. If you get a change on several and one not changing the engine then that injector is bad and needs to be replaced. I just found a 3020 D that was acting almost the same and I found the right brake was dragging just enough to cause it not to pull on hills and would pull the engine down. It was not applied enough that it affected the steering enough that you could tell it was dragging. We had to rebuild the brake peddle and that stopped the problem. I hope these suggestions help you with this problem.
msb
12-09-2005 08:01:51
Take the fuel line off going to the fuel pump and see if you have a good flow of fuel from the tank.Could be you have a partially plugged fuel line.Then clean the sediment bowl and replace the fuel filters.If that doesn't clear the problem up then it is a good bet the injection pump needs rebuilt.
ET
12-09-2005 05:14:32
Give it a good tune up. The fuel filter is the first thing, but what is the air filter like? Set the pump timing and ajust the valves. Make sure the thermostats work so it can reach operating tempature.
G/MAN
12-09-2005 05:10:46
Changing the fuel filter is the logical first step. Also, after letting it sit for a while, roller under the front-end and open the drain in the bottom of the fuel tank to see if you get any water out.
