G Light problem????
Davebr
12-08-2005 21:36:02
Hey Guys, Man it feels good talking about something other then trying to get the ole G started. Started it 3 times today. Anyway, I put all new wiring on it and my problems is that there are 3 lights on the tractor and only the right side and back light work. I have cleaned up the grounding points on the light itself, jumped it directly from the switch, battery, changed bulbs with one I know works. It according to the manual is wire correctly, one wire to the "L" on regulator to the light, one to each light and to the otherside of switch???? No juice. Anybody have any Ideas or ever have this problem?
Thanks,
Dave
xxxxxxxxx
12-25-2005 03:43:17
 Re: G Light problem???? in reply to Davebr, 12-08-2005 21:36:02
sounds like where your wire "T's"to the left side is broke or corroded, i had problems on my 48 g ,,so replaced all light wiring, and then had to wrap and clamp wire to bulb socket to get connection...and complete circuit.
van robinson
12-08-2005 22:15:21
Are you sure your switch is good? Are the light sockets corroded?
DickD
12-09-2005 05:21:36
 Re: G Light problem???? in reply to van robinson, 12-08-2005 22:15:21
Take a test light and start at the switch. If you have juice at the switch, and none at the light, and it will work with a hot jumper, then you must have an open short in your new wire.
