435 Knock on start up
Tsmith1499
12-08-2005 20:07:20
I just got this 435 and just received the manuals from Deere. It doesn't have much of a trouble shooting section in it. The problem I am having is that it is hard to start, even in a heated garage, and has what sounds like a crank knock on start up. The knock goes away in a minute and it is holding 50lbs. of oil pressure. One person said it was probably an injector problem. Why would the injectors cause this? I don't want to run it anymore until I find out what the problem might be. Thanks, Tom
buickanddeere
12-10-2005 07:02:21
 Re: 435 Knock on start up in reply to Tsmith1499, 12-08-2005 20:07:20
Most cold diesels knock and hammer even more than normal until they warm and the clearances reduce some. The early 53 series engine used the "S" series 17 to 1 comppistons and low pressure injectors. That's why so many 435's have had the front axle busted from crude hacks hooking onto the wrong place tow starting. Or the engine has been ruined with ether by having the rings and ring lands broken. Now the compression is even lower. Plus your 45 year old engine maybe worn out. In the past some tinkerer may have cost themselves money by saving money and only regrinding the valves and seats. This sinks the valves and drops the compression ratio further. New valves, seats,guides, updated cam foloower springs, up dated valve springs, N sleeve/piston kit, N35 injectors and the new blower seal update. The battery has to be a 900+ CCA with new HD cables and the starter in 100% condition. My 2-53 fires on the 2nd to 3rd turn at 30F without preheating. I plug it in anyways however. It has 21 to 1 N series pistons and high pressure N injectors. Amsoil 30 wt synthetic in the crankcase so it's doesn't get too thick either.
tsmith1499
12-10-2005 14:37:56
 Re: 435 Knock on start up in reply to buickanddeere, 12-10-2005 07:02:21
Thanks for the info. We just got this tractor a few weeks ago and I didn't want to try running it if something was terribly wrong. How would I check the compression on this engine, and what should it be. Normally you would pull a plug, but this isn't a normal tractor! It is a very neat tractor though.That's why my wife bought it. Now I get to work on it. I bought all of the manuals except someone told me that SM2019 was the shop manual for it. When I got it, it turns out to be the shop manual for a 420. I work at a John Deere dealer and we have not been able to find a shop manual for the tractor itself just the engine.
buickanddeere
12-10-2005 17:41:34
 Re: 435 Knock on start up in reply to tsmith1499, 12-10-2005 14:37:56
Manual(s) for the 440 industrial diesel wheel trctor the most accurate. It's safe bet the compresison is low due to wear and possibly an econo "over haul". Getting more cranking rpms and a fresh set of N injectors along with a block heater will do wonders.
