Hydr pump problems on 3010
Bison
12-08-2005 19:08:32
I had a leaking seal on the main hydr pump on a 3010. I replaced the shaft, bearings, seals and all the o rings. the filter was solid plugged but the rest of the pump looked fine. upon installation the seal started to leak again after 5 min running. This is the third set of seals that go in this pump, and they all leak soon after. The first two sets where installed by the dealer. Istallation of seals from inside to out is quad ring ,backup ring and lipseal last. lipseal is only as far in as the snapring. What can cause that seal to start leaking so soon. I do not know wether the quad ring leaks too, or just the lipseal. there is just a steady drip, no stream under pressure.
The pump pressure is full trottle 1900 psi, wich is to low but i did not even get time to reset it when it started to leak .
ANY SUGGESTIONS SOMEONE
Gord
12-10-2005 15:26:55
 Re: Hydr pump problems on 3010 in reply to Bison, 12-08-2005 19:08:32
The 3010 hydraulic pump does not have the external seal drain line. On the "10" series of hydraulic pumps there is a different lip seal used. The seal will tolerate higher crankcase pressure and leakage past the inner quad seal. If the dealership used the seal that is included in the repair kit then the pump will leak. There is a parts note in JD parts indicated which seal to use.
msb
12-09-2005 15:35:54
O.K. I was one of the guilty ones that didn't read the post closely,so I'll try again.Have you inspected the shaft closely for burrs or roughness? Could be the seal is being damages when the shaft is inserted through the quad ring.If that isn't it then I would suspect the crankcase pressure is too high.It should never be more than the transmission supply pump can deliver which is 150 psi.,if I remember correctly.
JGC
12-09-2005 13:32:54
Ok lads, the fella is probably really frustrated after having the dealer try twice to fix it and trying himself. Maybe we can cut him a little slack and suggest a few more things to try. Someone on the forum will think of the right solution.
Merry Christmas,
Jon
JD man in SD
12-09-2005 10:03:33
i would check brg race fit in housing on splined end it is common to be loose in this pump if it is i would replace the whole pnmp go to 20 or 30 seris $ install seal drain kit from Deere
ET
12-09-2005 05:18:24
Have you conidered a hairline crack in the pump housing?
msb
12-08-2005 20:04:50
The lip seal shouldn't leak unless the seal is driven in too far or the weep line that Bob mentions is plugged up.Driving the seal in too deep covers the drain hole for the weep line.The line is a small black plastic line that goes back to the brake valve area.The only other thing that I can think would cause this is an internal leak that causes the crankcase to be pressurized too much and that is overwhelming the lip seal drain (weep)line.A crack in one of the piston bores could cause this ,but the pump should go out of stroke if this is happening.Does the pump continue to build pressure?
Bob
12-08-2005 19:17:52
Was the pump endplay checked? Are the "weep" line fitting and line clear and open?
Bison
12-08-2005 21:10:31
 Re: Hydr pump problems on 3010 in reply to Bob, 12-08-2005 19:17:52
If you would have read my posting right it would have answered one of your your qustions about the lipseal. it is placed correct. this pump does not have a weep line. the drainhole between the seals is open and NOT blocked of by the seal. The bearing clearance is also correct.
The pump does hold its pressure.
I have been told by the dealer that pumpcrankcase pressure is the same as output pressure when the pump is out of stroke. All I can think off is to much pressure between the seals and that is probably connected to the intake side.
Remember the dealer replaced the seals twice and even failed to clean the filter in the pump.
Bob
12-08-2005 22:02:53
 Re: Hydr pump problems on 3010 in reply to Bison, 12-08-2005 21:10:31
Sorry for trying to help!
Mike M
12-09-2005 11:02:16
 Re: Hydr pump problems on 3010 in reply to Bob, 12-08-2005 22:02:53
Yep, glad I read all the posts before I gave it a whirl. Now I will just keep quiet.
Bob
12-09-2005 12:25:08
 Re: Hydr pump problems on 3010 in reply to Mike M, 12-09-2005 11:02:16
Like my Dad used to say, some people'd %&$#^ if you hung them with a new rope, and around here, some people %&$#^ over the FREE advice they get.
I guess it takes all kinds!
