494A Corn Planter
wayray
12-08-2005 04:50:24
When did John Deere first come out with the 494A corn planter? 1950's?
Would a late styled John Deere B have been used to operate a 4 row 494A corn planter?
Leroy
12-11-2005 08:05:41
 Re: 494A Corn Planter in reply to wayray, 12-08-2005 04:50:24
The 494 came out as a 57 model and for 58 they changed the hitch, fertilizer boxes and fertilizer drive, when the 494A came out they again changed the front part of the frame, put a fould up toung on and changed the fertilizer boxes again andchanged the press wheels to a live axle with bearings on end of axle instead of hub of wheel and this was for the herbiside and insecticide boxes, mid run of the 494A they went away from the gear box seed drive with differential to open gears with all chain chaingeing for speed setting and ratchets on the wheels for turning. The 12XX series is the same exact planter as the 494A if it is a plate type planter and I know my 494A is supposed to be a 69 model and I also have here a 57, 58, 59 model planters as well as 2 490 planters that were brought out for 42 year sales thru 56 and those could be bought with either clutch lift or later hydrolic lift. I also have a 450 planter that was made from late 30's to 42 and was first 4 row planter Deere made.
Maark
12-08-2005 12:58:49
The 494 planter came out in the late 50's. Your B pulled a 490 when new.
Mike Aylward
12-08-2005 15:23:48
 Re: 494A Corn Planter in reply to Maark, 12-08-2005 12:58:49
The 494 corn planter came out in about 1957. They were superceded by the 494-A in about 1963. The later planter differed from the regular 494 mostly in the front frame being square tubing instead of round tubing (so the fertilizer openers would stay "put" better) and also had larger fertilizer and insecticide hoppers. Like the other poster said, the 490 would be "age appropriate" for your late B. This being said, thousands of these planters were pulled by late B tractors. Hope this helps. Mike
