Clooney or John T dead battery
JDG
10-26-2003 21:28:35
My 47 G runs battery dead in about 3hrs of running time. Amp gauge shows charging 10 to 12 amps. Has gen, dist and off & on ign switch.What is the problem?
John T
10-27-2003 12:12:04
 Re: Clooney or John T dead battery in reply to JDG, 10-26-2003 21:28:35
Hey G Guy, we cant have that discharging, especially now that shes gettin colder huh???
Im not quite sure what the problem is, but heres a few thigns to consider:
1) Is the ammeter wired right?? If you turn on the lights or ignition with her off does she show a discharge?? Is there a good solid continuous NON SHORTED connection from the ungrounded battery post, like at the battery itself or the starter post, to the battery side of the ammeter??? A test lamp or voltmeter there (on BOTH sides of the ammeter actually) not running needs to show around 12.6 volts. There shouldn't be any other wires on that side of the ammeter, or else the charging current may be going elsewhere than the battery. The other load side of the ammeter is where the loads like lights and ignition and switches etc should be, is that where your lights and switches and ESPECIALLY the generators output wire is now (i.e. the wire up from the BAT terminal on the VR)
2) Have you done any basic generator/VR checks to see if theres any gen or VR problem? Im sure you have seen this here before, but with the tractor runnign at RPM, temporarily ground out the Filed post on the gen and see what the ammeter does and if it now charges more???? Then leave that and also jump the VR's BAT and GEN (or ARM) terminals to by pass the cut out relay and look for any (when running) changes. If shes chargin as you say, those by pass tests shouldt show much major change other than perhaps slight charge amp increases.
3) If the ammeter is wired right,,,,, , and the gen/VR is actually charging and wired right,,,,, ,,,,,but the battery still eventually discharges, theres still more amps gettign out of it somewhere than the amps getting in (if the battery is good), in which case I would look for some wirign shorts (discharges) OTHER THAN that which is passign through the ammeter. If the ammeter is wired per the above with only the bat on one sie and ALL loads (lights, ignition) PLUS the generators output on the other, that should be the only in/out current path UNLESS theres a short somewhere which is sucking up some of the gens output and/or its not actually getting into the battery.
4) Have you had the battery load tested or tried another substitute and see what happens????? See if it has electrolyte above all the plates and none have a gray or milky color????? ?
5) Check the wiring and grounds on the gen and VR cuz a bad ground can allow current to be drawn which isnt necessarily all getting into the battery. Run a ground wire form the battery to the gen and VR and attach it.
6) The ammeter should be near a dead short and continuous between its terminals but not, of course, have any curent paths to ground, and wired as above. You might try new wires from the VR's BAT up the the ammeters load side and one from the BAT side direct to the battery or hot starter post to insure no shorts.
7) If its not any gen or VR or shorted wires (especially from the ammeter) or a bad ground and the ammeter is wired right and actually charges, the I suspect the battery may be bad.
Post back your results and any more questions or e mail [email protected]. If not the battery, I suspect a bad ground or a mis wired ammeter or a shorted wire somewhere (not passing thru the ammeter) discharging more current out of the battery than the gen can supply.
If the ammeter is wired right but not working properly maybe you arent really getitgn 10 or so amps charging as you said??? If you rev the old girl up, do the lights glow noticeably brighter, which indivates a charge??? if you place a voltmeter on the battery, does it show 12.6 not runnign but raise to 13 to 14 running??? If so that again indicates charge. If neither of those tests pass, maybe the gen isnt actually passing amps to the battery via the ammeter, despite what the ammeter says????? ? TAKE A LOOK AT THOSE 2 TESTS and let me know and do the generator/VR by grounding and by pass tests above to see if she charges and raises the battery voltage then (volts raise and lights brighter). If so maybe shes not charging is why the bat runs down????? ?
CHECKS ALL GROUNDS (including gen and VR), AMMETER WIRING, LOOK FOR SHORTS, VERIFY BATTERY IS CHARGING VIA VOLTAGE INCREASE OR BRIGHTER LIGHTS
Good Luck n God Bless G Guy
John T
Thanks John
10-28-2003 05:40:41
 Re: Re: Clooney or John T dead battery in reply to John T, 10-27-2003 12:12:04
Even if I didn't ask the question I can't belive the time and efort you put into your replies. I soak this stuff up like a sponge!
John T
10-28-2003 07:56:35
 Re: Re: Re: Clooney or John T dead battery in reply to Thanks John, 10-28-2003 05:40:41
Your welcome, Hope you get her figured out, lemme know John T
