1936 John Deere Model D
KenC
12-07-2005 15:46:09
Just received my JD D purchased from an auction. Nice machine and seems to run well. Noticed two issues. PTO barely rotates and parking brake does not engage.
Any diagnosis and corrective action is appreciated.
Thanks,
Glen in TX
12-07-2005 22:31:28
 Re: 1936 John Deere Model D in reply to KenC, 12-07-2005 15:46:09
The PTO on your D is gear drive. It's either in or out and going to run engine speed when PTO box is in gear and clutch is engaged. The D PTO was only rated at 525 RPM. A 36 D should have the internal transmission parking brake yet. There is nut on top of transmission for adjusting the brake. Tighten the nut until the brake lever stands vertical when brake is locked on and it should rest against the stop towards rear when off. It may need relining or have worn or broke parts inside. JD D Instructions for Service and Operation Dir. 225 covers Ds 1931-38 and is available from JD tech pubs. The 37 and later Ds had a optional service brake on the outside of transmission using a foot pedal.
