Clearing out engine and transmission case
Lesterr
12-07-2005 08:55:12
I am parting out a 60, I have the engine and transmission case remaining with all the gears & shafts inside. A freind needs the engine and transmission case but not any of the gears...is there any trick to getting the gears and shafts/bearing out quickly? I believe it is straigh forward, but from the looks of it, it could take days to remove all these items.
ANy trick or tips of how to do this best?
magoo1
12-08-2005 11:58:41
 Re: Clearing out engine and transmission case in reply to Lesterr, 12-07-2005 08:55:12
I need the reverse gears for a 60/630. Mine was used on a cotton picker and goes really fast when trying to hitch to something.
I'm not sure what I need to change, but sure it is a set.
Let me know about price ect.
Thanks Sonny
229-723-4029
G/MAN
12-07-2005 16:34:32
Beg, buy, borrow or steal a "60" repair manual. There's nothing super-difficult about two-banger trannies, but following the right procedures will minimize damage to potentially valuable parts and save a lot of headaches. A good 5 or 6 hours should pretty much have a two-banger main case gutted easy enough. It didn't take them days to put them together in Waterloo, lol. What other goodies are left on the old girl?
Mike M
12-07-2005 09:41:19
It's not that bad,I used to be able to pretty well tear down a whole tractor in a day back when I was doing that. I have also done several so I knew what tools and pullers I needed and what needed to come off in what order. Tear down on most stuff is the FUN part and usually goes a whole lot quicker than the clean up (not fun)and reassembly. Just take your time so as not to break more than you save as these parts are getting scarcer everyday.
forgot to add
12-07-2005 09:45:38
 Re: Clearing out engine and transmission case in reply to Mike M, 12-07-2005 09:41:19
You say friend. That's even better ! You both can work on it makeing it go faster and learning alot along the way. Very usefull to put the other one back together !
RalphinWI
12-07-2005 10:23:54
 Re: Clearing out engine and transmission case in reply to forgot to add, 12-07-2005 09:45:38
Excellent idea!!!
