3010 Diesel knock
dgkirk
12-07-2005 07:59:46
My 3010 diesel was overhauled about 8 years ago after a spun rod bearing. Crank was turned. Now I suddenly developed a loud knock that sounds like it"s in the engine even at idle, no load. Still have 30" oil pressure, it starts okay although doesn"t want to run on 1 cyl. for awhile. Engine has probably 200 hrs. since overhaul and has not been worked hard, overheated or run low on oil. Figure I will drop the pan first, but any other suggestions? Front hyd. drive seems solid. A observing JD mechanic thought it didn"t sound like a rod knocking. Sounds like a hammer being applied to an anvil with a lot of force. Help! Any suggestions where to look before tearing the engine down?
Thanks.
3010_Floyd
05-01-2006 00:22:25
 Re: 3010 Diesel knock in reply to dgkirk, 12-07-2005 07:59:46
My 3010 Diesel mhad that same knocking sound. I didn't hear it when the engine first started, however, ten to fifteen seconds later, the knocking would start. I forgot how I came to check, but, the coupler at the crankshaft/harmonic balancer that attaches to your hydralic pump up front, under radiator, has two thick massive rubber O'rings. These rings fit onto the coupler. I replaced the coupler and the two thick massive hard rubber O rings and the knocking disappeared.
I'd recommend disconnecting your hydralic pump at the harmonic balancer/crankshaft.. It sits directly below radiator and start the engine.
~~~~~~~~~~~~~~~~~~~~~WARNING~~~~~~~~~~~~~~~~~~~~~
DO NOT TAKE THE TRACTOR OUT OF PARK OR ATTEMPT TO DRIVE IT WITH HYDRALIC PUMP DISCONNECTED~~!!!
"You will have no brakes or steering"
I'll bet that knocking is gone. Let me know, hope this helps.. Lloyd
Bison
12-08-2005 18:36:51
On second thought check for a lose flywheel, that was the cause for a bad knock like it had lost a rod bearing on 3010 from a nabor. you can check that trough the timing cover on the bell housing.
Bison
12-08-2005 18:32:06
check also if the engine balancer has lost a bearing or has a worn gear where it meshes with the crankshaft gear. That caused a knock in my 3010. Pull the filter and sleeve out of the pan, you might be able to check the balancer trough that hole.
Mike W J
12-08-2005 15:23:47
We had a 4010 that sounded like that It had a bad bent pushrod and the knock was when the piston went down it had to suck the valve open then it would slam shut when the piston changed directions causing a Hard rapping sound. Did this start in cold weather? Let us know what you find.
jas
12-07-2005 19:09:23
Before you pull the injector, loosen the line feeding it at the injector while the engine is running.. You might find the knock goes away when you've found the right one. Then pull it and check it. By loosening the lines and listening to the change in pitch of the motor, you will find the strong and weaker cylinders.
jdmike
12-07-2005 18:06:25
A diesel engine will have what sounds like a rod knock if an injector is over fueling a cylinder or has a bad spray pattern. That could be the reason you are loosing 1 cylinder when you first start it. Pull that injector before you mess with the bottom end, if you have a spare injector, replace that one, bleed the injection system real good and see if the knock goes away.
donmyeil
12-07-2005 12:47:22
I would pull the injector for that cyl and look at the tip to see if the end broke off. Another possibility is a broken ring has finaly made its way to the top and is now on top of the piston. This will sound like either when this cyl. fires and it will come and go.
