A parts interchange with 60 parts?
chadmn
12-06-2005 15:59:20
can anyone tell me if a starter and a drawbar are interchangable between a 60 and a late A? thank you in advance
Mike Aylward
12-07-2005 14:41:40
 Re: A parts interchange with 60 parts? in reply to chadmn, 12-06-2005 15:59:20
Chadmn, the starters are the same. The drawbar will physically fit but will be the wrong length for the proper PTO geometry. The drawbar frames are also different, although one will fit onto the other. The 60 will take two different drawbars depending on whether or not it has live PTO. The regular PTO drawbar is shorter but I believe it is still longer than an A drawbar is. Hope this helps. Mike
Mike M
12-06-2005 18:43:31
Yes they will. But on that drawbar if you have live pto on the 60 and NEED it to be the right length for pto operated equipment the adjustment holes may not match up right.
Glen in TX
12-06-2005 17:18:19
Some will and some won't depending on which type drawbar and serial number. Check a parts book.
buickanddeere
12-06-2005 17:05:21
1-800-522-7448 for the parts books.
