630 Transmission Problems
8e3k0
12-06-2005 10:36:15
I have a 630 general purpose that the transmission is giving me some weird problems.
All gears forward and reverse work and hold in good. When you shift from low range side to the high range side the gears all work okay in their respective positions. When the shift lever is moved from the high range side to the low range side and put into reverse nothing happens when clutch is engagged just as if it is still in neutral. When you shift to second and back to reverse you have reverse gear and all other forward gears on the low range side work okay and shift nicely, but if you go back to the high range and back to low range you must shift to second first and out to get your low range gears back. Any thoughts or ideas as to what's happening would be appreciated. I have not had time to review the tech manual or lift the shift quadrant off yet to inspect, same old story,other priorities. Could it be on the forks or the sliding rails? Just a bit puzzled at this time so if anyone has come accross the problem I would appreciate your help in solving this problem. Thanks
Ellis
Mike M
12-06-2005 12:52:14
 Re: 630 Transmission Problems in reply to 8e3k0, 12-06-2005 10:36:15
A common problem of worn shift forks (where the lever goes in)not letting the high /low make a complete shift. You should be able to feel it go in if you work it slowly. I have had good luck building them back up with weld after pulling them out.
