3010 John Deere - Gas
Larry Lathey
12-06-2005 07:07:29
Anyone have a clue how I can get my PTO to kick our of gear. It runs all the time. Also I need some specs on it. It is a 1963 model, I think. Anything you have I would appreciate. This one is new to me. Thanks.
msb
12-06-2005 18:20:17
 Re: 3010 John Deere - Gas in reply to Larry Lathey, 12-06-2005 07:07:29
Probably just the big detent pin that keeps the brake from coming on is frozen up.Its located inside the kick panel and is a part of the PTO lever.It is a round head pin that is spring loaded.Squirt some penetrating oil on it and jerk the lever back and forth until the pin comes loose so the barke can come on.
msb
12-06-2005 18:20:27
G/MAN
12-06-2005 07:33:18
It's possible that the PTO brake isn't working, and the shaft is more or less being turned by "drag" in the PTO system. Will it pull a load in the off position?
Larry Lathey
12-06-2005 07:40:15
 Re: 3010 John Deere - Gas in reply to G/MAN, 12-06-2005 07:33:18
Don't know if it will pull a load in that position or not, havent tried that. It keeps spinning all the time whatever I do. Thanks for the reply , I can use all the help I can get.
G/MAN
12-06-2005 10:13:26
 Re: 3010 John Deere - Gas in reply to Larry Lathey, 12-06-2005 07:40:15
CAREFULLY try to stop the shaft with something - not your hands - with the engine at a low idle. If you can put a prybar or something against it and it stops, you have a brake problem.
Mike M
12-06-2005 07:11:24
It could be a stuck facing ? Sometimes rust sticks them. You could try running it on a heavy load like a dyno and see if it pops free ?
