JD 5420 mid SCV Freezing-up
burnetma
12-04-2005 18:28:54
The mid-mount SCV's that are used to control my FEL have been freezing up. When I first start the machine, the valves will not move. I can not even rotate tham by hand. After the unit runs for a period of time and the fluid warms up, the valves will eventually work free. The three point system works fine all of the time. Interestingly, the top valve seems to freeze up more often. This morning for example, the lower valve (bucket curl) worked fine, but the upper valve (bucket lift) would not move. The tractor only has 200 hours and is used primarily as a bucket tractor outside of haying season.
Questions:
1. Is it possible that the seals on the valve are pulling in atmospheric moisture and then freezing?
2. Can I test the hydraulic/trans fluid for moisture?
3. How can I get water out of the system, if there is water in the system?
Gerry_Luzerne_MI
12-05-2005 05:34:14
 Re: JD 5420 mid SCV Freezing-up in reply to burnetma, 12-04-2005 18:28:54
I bought a new 5420 3 years ago and my mid SCV would stick, not return all the way to center. I was not happy when the dealer told me to use it more. "Put more hours on it". I think what they were saying was it was tight. Not sure it this helps. You might change the oil. I think mine called for a filter change at 100 hours or the first year of service. Gerry
nw_bearcat
12-05-2005 05:26:31
Father in law has a 6400 w/ a 640 loader. He has had some issues with the joystick not working right in cold weather. Took it to JD dealer, and apparently it is a common problem with the cables for the factory JD loader. Kinda of a pricy project to fix for no more than they are, but doable.
JStacey
12-04-2005 19:30:36
This is a warranty issue. Contact your JD dealer. Sounds like a possibility of moisture in the cables.
burnetma
12-09-2005 16:33:50
 Re: JD 5420 mid SCV Freezing-up in reply to JStacey, 12-04-2005 19:30:36
I called JD out for a service call. The Tech found moisture in the valve cap that was freezing up the spring. Simply took a heat gun to her and melted out the ice and continued until it was dry. Cleaned out that cap and applied more grease.
The service tech is looking into a modification of the cap to prevent this from happening in the future. I guess it has been done on other models with some success. No real big deal to fix otherwise. I will just add it to my maintenance checklist.
