4020 more power
ES
12-04-2005 17:44:26
like to get little more HP out of it to do alittle pulling cant ad turbo any suggetoins dont want to brake the bank is 140HP posible thanks for any help
ES toJD JACK
12-05-2005 16:18:19
 Re: 4020 more power in reply to ES, 12-04-2005 17:44:26
what did you do to yours to get 118 HP if you don t mine telling this tractor will not see mutch more farm work thanks
JD Jack
12-06-2005 19:50:51
 Re: 4020 more power in reply to ES toJD JACK, 12-05-2005 16:18:19
I actually didn't do much! Complete overhaul with the predator kit, new cam, some head work, new injectors and a well turned injection pump. You could do a lot more than I did, especially with the head work. It just depends on how much you want to spend in the machine shop. The most important thing is having the injection work done right. That is the one thing I can't take credit for. The pump I have was on the tractor when I bought it used. I never touched it and have tried(unsucessfully) to find out who worked on it. I am guessing that the governor springs and smoke screw were tweeked, but I'm not a injection expert.
If your engine is in decnt shape you could skip the engine work, but mine needed the work really bad. As with any injection and engine work, the most important thing is to check around before you have any work done to see who is good and reliable and knows their deeres.
This setup has worked really well for me. I use this tractor for farming and it is my "big" tractor. I have never had any problems with overheating or the tranny in the 10 plus years I have had it, so I would say you should be fine running yours at that HP level.
4010 puller
12-08-2005 19:42:08
 Re: 4020 more power in reply to JD Jack, 12-06-2005 19:50:51
JD Jack:
What is a predator kit? Where do you get them? How much do they increase your power?
Thanks
G/MAN
12-05-2005 07:17:56
It'll probably hold up for short periods during tractor pulling, but taking it to the field and pulling it for hours on end at that horsepower level probably isn't smart. 4020 blocks lack piston-cooling jets, and cranking them up excessively can easily lead to scored pistons and sleeves.
jdemaris
12-05-2005 04:57:01
I suspect 140 horsepower would be easy to achieve with a turbo and propane injection - considering the 4020 is direct-injected. The subject of how well it would hold up, or be able to cool itself is a different story.
buickanddeere
12-05-2005 02:45:47
Trade for a 4320 or 4620. Running a 33+ year old 4020 at those HP levels will get expensive.
JD Jack
12-04-2005 19:43:11
Depends who's Dyno you use! They can vary greatly! Anyways I feel 140 is pushing it if you want to use the tractor for any work for any period of time. It will probably overheat or worse. I have heard of one that pushed 130, but that was a while ago and I don't know how acurate the dyno was. I currently have a '64 4020 that is putting out 118 acording to the new dyno my local dealer got this summer. I have had some work done on mine so the 120 range is a good area to shoot for.
