1947 John Deere B--(Carb or Governor problem?)
Larry 2809C
12-04-2005 16:29:55
When i advance the throttle on the B, the butterfly on the carb jumbs back and forth (from close to wide open) very very fast until full RPM's is achieved. I have checked the linkage and have it set to 1/2 hole short when the throttle is wide open and the carb butterfly it wide open. This just does not seem to be right and wondered if anyone else has had this problem.other then this the tractor runs well...thanks for your help
JGC
12-05-2005 15:08:13
 Re: 1947 John Deere B--(Carb or Governor problem?) in reply to Larry 2809C, 12-04-2005 16:29:55
A few additional thoughts:
1. Be careful not to over-rev the old girl when you are manually controlling the throttle. The maximum high idle is only 1340 to 1370 rpm and these engines accelerate very quickly without a load! I bought a hand-held tach when I started up my "D" and I was amazed how slow 980 RPM is!
2. I had a similar symptom on my "D". There were a number of small problems that contributed to it. The hole in the brass throttle lever that the governor rod drops into was badly worn. I bought a piece of very thin-walled tubing at the local hobby shop and I carefully reamed the lever to fit the tube O.D. and fill the gap. Also, the carb which I had overhauled was not delivering enough fuel mixture as the engine came off the idle stop so the governor rapidly opened and closed the throttle trying to maintain medium RPM.
Check carefully for ANY binding or stiffness over the full range of movement of the throttle lever with the throttle rod installed. Any change in the force required to open and close the throttle indicates binding condition which you will have to fix.
All this assumes that there aren't serious problems inside the governor or carb!
Duane Larson
12-04-2005 16:57:45
Larry,
The flutter in the butterfly operation likely is caused by your governor. Start with the governor rod in the butterfly (without the cotter pin) and start the tractor, then hold the carb butterfly with your left hand and remove the governor rod with your right. Then change the engine speed manually by opening and closing the butterfly. When you are doing this, the governor rod should move smoothly and positively. If it does not move, jerks, or oscillates back and forth, you will need to look into your governor. If it operates properly, you have a problem elsewhere, probably either with the linkage or your carburetor. Post back and we'll go from there.
