1950 A crank
Coastie Jim
12-04-2005 10:57:55
Guys,
My dad has a 1950 JD A with M & W power kit to include the block, pistons and possibly the crank. The splines on the crank are severally worn and the clutch chatters. My question is whether a stock crank will work with the power block pieces or not. I have a line on an original crank with correcct Part# but am not sure it will work with current power block set-up. Thanks for the help.
fixerupper
12-04-2005 20:25:20
 Re: 1950 A crank in reply to Coastie Jim, 12-04-2005 10:57:55
I fixed the splines on a 51 A with the crank in the tractor. It took some time and patience but the finished job has held for 20 years. I welded on top of the splines a little at a time and then ground it down and tried the fit. When I thought I was finished I bolted the drive disk up tight and put a dial indicator on it and found it had a very slight wobble so it was back to the drawing board for another hour, welding and grinding. Finally got it right, though and it took a lot less time than removing the crank would have. Give this a try first, you have nothing to lose unless you get really wild with the welding. Remember to weld just a little at a time to keep it cool. Just find a comfortable chair the right height so you can sit down while you work, get a cup of coffee, tune the radio to a soothing station and go to it. Jim
Earl-IL
12-04-2005 17:02:26
What are the casting numbers on your block (top side)?? Earl
Miller49G
12-04-2005 11:21:55
Yes the stock crank will work with the powerblock pieces. It will bolt up just make shore you got the correct powerblock for your tractor. And you also can get that crank fixed. I had one repaired on my G. Go to my web site and look at Crank rebuild tab.
Eli
12-04-2005 11:07:02
I,m not sure if it will work, but I do know your crank is repairable. Good luck, Eli.
