4640 hard cranking
Mike Nelson
12-04-2005 07:35:48
I have a 1981 4640 that doesn't crank good when it's below 50 degrees. After getting it started the first time, it starts good the rest of the day. The problem is it doesn't crank the engine fast enough for it to start. It will crank slowly for about ten seconds and then stop. Then I have to wait about a minute to try it again. The only way I can get it to start is jump it, sometimes I even have to double jump it. I have new StrongBox 6volt batteries and good cables. Everthing on the tractor is factory. What do I need to check?
jdemaris
12-05-2005 06:08:15
 Re: 4640 hard cranking in reply to Mike Nelson, 12-04-2005 07:35:48
Nine out of ten times, persistent cold-cranking problems with Deere tractors are caused by the hydraulic pump - not the starter and/or wiring. Changing from two 6 volt batteries hooked in series - over to two 12 volt batteries hooked in parallel - will make absolutely NO difference - unless you've got a source for better quality batteries in either voltage. In general, two 6 volt batteries that have a total weight equal to a pair of 12 volt batteries will have the same total output, CCA, etc. 6 volt batteries have heavier internal plates and usually outlast their 12 volt counterparts. On the otherhand, two 6 volt batteries hooked in series draw more current through the cable joining them - so it must be in good shape and sized properly. If you've ruled out problems with the starter, batteries, or wiring - install a hydraulic pump destroker and there will probably be a huge difference in starting and cranking.
nw_bearcat
12-05-2005 05:31:48
do you have "good" cables, or do they look good? We've had problems with the cable that runs under the cab on the 4430's and 4440's on our farm. they look good, but for some reason, we replace them, and it will go. we can clean the terminals of the old cable till we're blue in the face, but a new cable will get us up and running. now dad replaces that cable everytime he changes batteries.
JD man in SD
12-04-2005 15:45:08
i would pull starter & check for worn or stuck brushes
jddriver
12-04-2005 14:51:26
On our 4430 and 4640 I replaced the 6v batteries with two 12s wired + to+ and - to - and ran the pos all the way to the starter from both batteries and the - also.I know this is not factory but it has eliminated all fo our starter and alternator problems.They also start better due to increased starter rpm.I used stud type group 31 bateries of the700 ccas at 0 degress any more amperage than that and the batteries dont seem to deal with the vibration as well.Might not be the polictically correct way but it worked for us.Steve
buickanddeere
12-04-2005 10:40:57
Measure the voltage before during and after cranking. Between the large main copper post going into the starter motor and the starter motor's cast body.
Dave in Ohio
12-04-2005 08:01:25
Get someone to do a Starter Draw test. You might have a starter that is about to go belly up on you.
mecanik69
12-04-2005 07:59:05
Sounds like a bad starter.
