80 Tach Cable
superfarmer
12-04-2005 07:33:39
Does anyone know where to find a tach cable for an 80 other than through JD? They want about $120 for the whole cable, and all I need is the inner cable. Possibly there's another machine with the same length cable, 80" I believe. Thanks.
WeirdDeere
12-04-2005 16:20:46
 Re: 80 Tach Cable in reply to superfarmer, 12-04-2005 07:33:39
A+I parts has the whole cable for about $30. It has a plastic outside instead of the original steel. It fit my 80 just fine. Seemed OK quality. BUT I will note that my tach stopped working after a few months...I haven't looked yet to see if it was the cable, or the tach itself (it is original, and has some issues-non working hour counter).
I was able to order the cable through my Deere dealer (They told me about the A+I, very nice of them, since I almost got the Deere version, which was still expensive at the time).
Or you can go to the A+I parts website at:
Link
Brandon
superfarmer
12-04-2005 20:36:23
 Re: 80 Tach Cable in reply to WeirdDeere, 12-04-2005 16:20:46
This one just has the plastic tube but didn't have any cable to start with. I've used A&I parts before and had good luck. Do you know the part number off hand? Thanks.
WeirdDeere
12-04-2005 20:53:19
 Re: 80 Tach Cable in reply to superfarmer, 12-04-2005 20:36:23
The number is the same as the JD part, AR1318R.
Brandon
superfarmer
12-05-2005 04:44:52
 Re: 80 Tach Cable in reply to WeirdDeere, 12-04-2005 20:53:19
That must be the one he priced teh other day, cause the JD version comes up at $121 and the A&I is $39 (CAN). What we found odd was that the book lists two different inside cables for S-W or ?Delco tachs, but the same replacement assembly. Should work, I'd rather try one of those than the expensive ones. Thanks.
WeirdDeere
12-04-2005 20:21:25
Curiousity was killing me so I just went out and looked at the 80. The internal cable broke. It was loose where it attaches to the cable drive, and it broke right there-so the failure is probably my fault for not getting it tight enough.
Brandon
Mike M
12-05-2005 03:30:43
 Re: 80 Tach Cable in reply to WeirdDeere, 12-04-2005 20:21:25
Did you put lube on the cable ? They need lubed.
Billy Ben
12-04-2005 14:33:37
Had one made up at a speedometer repair shop a while back
Mike M
12-04-2005 07:47:18
Check with a local NAPA store. I just bought a kit for a speedo cable for $8.00 and used it to fix my broken tach cable on a backhoe. Also some of the semi truck parts stores can make them up.
