Flywheel Spacer Questions
MACE
12-04-2005 04:52:15
How important is it that the spacer be clocked and marked where it sits behind the flywheel? I remember where my spacer was at but did not mark the exact location. Or do I have it all wrong. I did mark the location of where the flywheel was on the crankshaft before I pulled it off. I neglected to do so with the spacer and crank. Feel free to throw your opinions and advice my way.
Thank You,
MACE
Maark
12-04-2005 09:40:58
 Re: Flywheel Spacer Questions in reply to MACE, 12-04-2005 04:52:15
Yes replace that cork seal now. When you reinstall the outside housing around the spacer, make sure it has the same clearance all the way around the spacer.Those bolt holes are a little oversize to allow for adjustment.
P Browning
12-04-2005 06:26:43
MACE -- be just a little bit careful in rotating the spacer on the crankshaft to achieve alignment. Inside the spacer is a seal, usually cork or something very similar. And if the spacer is withdrawn from the main bearing hsg far enough, the seal will be located within the splined part of the crank -- rotating the spacer on the splines will usually damage the seal. You should be able to rotate the spacer to align with notch in flywheel WITHOUT moving the spacer outward (away) from the main bearing housing.
Mike M
12-04-2005 05:02:37
The spacer has a notch in it that the pin on the back of the flywheel MUST go into to drive it as it is a slinger and must turn with the crank.
MACE
12-04-2005 09:37:35
 Re: Flywheel Spacer Questions in reply to Mike M, 12-04-2005 05:02:37
Hello,
Thank you for the replies to my questions. I now understand what I need to do. Do I need to replace the cork seals in the spacer while I have it out?
Thank You,
MACE
