'48 G part# AF933
Roy Hobbs
12-03-2005 17:05:07
I had a serial# research done on my G. It came back stating:Special equipment-af933,and then stated cast steel disk wheels and what tires were on them.I went through my parts catalog and checked all wheel options found nothing.Then I checked the numerical index.It goes from af921 to af953.I'm wondering what this # is.If it is the wheels,I wonder why they are not in the parts catalog? Thanks for any help.
Duane Larson
12-03-2005 18:00:23
 Re: '48 G part# AF933 in reply to Roy Hobbs, 12-03-2005 17:05:07
Roy,
The 11-28-1949 John Deere price list for a G shows "Model G tractor with AF-933-R wheel equipment consisting of 6.00-16" 4-ply front and 12-38" 6 ply rear rubber tires and tubes, with cast disk rear wheels". The assembly number AF-933-R was for a one-piece pedestal, and was different for a split pedestal. I'm not sure what made Two Cylinder call it "special equipment".
Such numbers are given to assemblies, in this case of a particular set of tires and wheel equipment. Parts books tend to list the individual components of these assemblies, but not the assembly number. Assembly numbers are most commonly found in Price Lists.
Roy Hobbs
12-03-2005 18:09:42
 Re: '48 G part# AF933 in reply to Duane Larson, 12-03-2005 18:00:23
Thank you for the info,Duane.
