JD 510 anti-freeze in oil
ron bond
12-03-2005 16:00:36
I'm thinking of buying a 510 diesel. The oil is creamy coloured.I was told the sleeve "O" rings are the usual cause.IT STILL RUNS BUT WILL HAVE TO BE FIXED.
ANYBODY HAVE A COST OF THE SEALS AND OTHER PARTS AND A COST TO INSTALL.
thanks
ron
R. John Johnson
12-04-2005 16:26:20
 Re: JD 510 anti-freeze in oil in reply to ron bond, 12-03-2005 16:00:36
I have a 510 that had a similar problem several years ago. A sleeve pitted through and let coolant in the crankcase. The tractor had sat for several weeks in the fall and I was going to unhook the mower, change oil and put the tractor away for the winter. I checked the oil before I started it and noticed it was over full, but thought nothing of it. Ran it for about an hour, then dropped the oil, which came out milky grey.
That short run ruined the main and rod bearings, but thankfully the crank was OK. Buickanddeere is right. At minimum new sleeves and pistons, and new bearings. Strong possibilty of a crank that will need to be ground. With a tractor that old, who knows what else you will find when you are in there. Price these out repairs and compare them to the cost of the tractor.
Good luck
John
buickanddeere
12-03-2005 18:21:28
Are you in Canada or bought this tractor from a "tractor jockey"? That three cylinder engine is very similar to what was used in the three cylinder 20 series tractors built in both Mannheim and Dubuque. Odds are some cheapskate never checked the ph of the anti-freeze, only checked the freezing point. Count of getting that early 1960's tractor for about free as it may need a pile of parts as anti-freeze doesn't lubricate.
