Installing an inline gas filter, but wanting to be
Tyler-MO
12-03-2005 14:56:52
Hi everybody,
I"m restoring a JD 60 gasoline row crop for a good friend of mine. The tractor will be subject to sitting for long periods of time and not being used much, so I want to take every step for prevention of problems. I"m going to install some sort of in line fuel filter. Does anyone have a good suggestion for a fuel filter tht will be able to keeps it"s appearance from being too gaudy or just telling everyone: farmerfied!
Thanks,
Tyler in rainy cold missouri
johns48b
12-06-2005 18:26:17
 Re: Installing an inline gas filter, but wanting t in reply to Tyler-MO, 12-03-2005 14:56:52
i have found that by rolling up a piece of stainless steel wire very tightly with a very fine mesh to it and sticking it down into the fuel filter body part that goes up into the tank it will hold back some rust and dirt and let fuel flow to the bowl. cut the wire where it sticks up into the tank at least 1 inch. the fuel stabilizer is a must all year round. todays gas goes bad after 30 days i've been told. i use it in all my small engines when i put them up for the winter. although i try to crank them once or twice all winter the stabilizer fixes them where they will crank next spring without having to tear the carbs down and cleaning them
F-I-T
12-03-2005 18:39:05
Tyler:
I don't advocate an in-line fuel filter in a non-pressurized system as the standard sediment bowl does a fine job if you have all of the screen filters in place in the bowl and in the carb.
If you have assured yourself that the tank is rust-free, I think the standard sediment bowl assembly does a great job at sifting out heavy particles. Apart from that, tell your friend to shut the fuel off and run it dry after each session, which should minimze rusting in the carburetor. Might not be a bad idea to add some fuel stabilizer which will minimize varnishing.
Now if you still have any rust in the tank you need to take care of that and not depend on trapping it in a filter.
Frank
F-I-T
12-03-2005 18:38:54
Tyler:
Frank
old
12-03-2005 17:23:48
I would put one in, they cause more trouble then they are worth. Been there done that and found out the hard way. And yes its cold and rainy here in Missouri, whould prefer snow over the rain. Any snow after next Saturday would be just great, that way you can see the deer a long ways off. LOL Ya I'm in Missouri also, and have a 60 parts tractor here.
