Another Update on No Spark Mag.
davebr
12-03-2005 13:01:42
John and Glen Thanks for your help. This is a Wico XH (brand New). Here is what I have done since last post. I took the mag off, retimed, got her to spit and run for about a minute a couple of times but won't keep running. So, I took the mag off again and did what you said, faced the lugs towards me, wired it, got a little spark, not as blue as last time, rotated the flywheel toward the front of the tractor till my thumb popped off the spark plug hole #1 piston on left side of tractor if sitting on the seat, piston was towards the head, put the mag on , rotated towards front, turned the flywheel towards the front of tractor one full turn to line up the LH Impluse mark, tapped mag towards back till pop, tightened her down, hooked it all up with #1 cylinder spark plug wire in top hole of mag cap, tried starting it, nothing then she back fired. My ears are still ringing. This is on a GW, Serial# 44839, it has gas in the tank and is getting it to carb. This is a newly rebuilt #51 big nut. That is where I am. I could just get my 50 cal. Desert Eagle and put the tractor out of its misery??? haha.
Thanks,
Dave
Maark
12-03-2005 15:22:19
 Re: Another Update on No Spark Mag. in reply to davebr, 12-03-2005 13:01:42
Do as Carl says, sounds like you have the mag 180 degrees out of time. When you bench test, do you have spark at both plug wires everytime? If you take the mag off again, place the mag in a vice[I usually clamp the bottom bolt hole flange in a vice to hold it steady], with the drive lugs pointed towards you, attach a vicegrips to the drive lug, turn the drive lug ccw and determine which spark plug is firing, then turn the drive lug cw then ccw in succession and make it fire repeatedly on that plug wire and see if you have spark everytime. If not it could have a bad cond.If you have flooded that tractor while fighting this problem, you may need new plugs also. Wish I was there to help in person instead of snowy Iowa today.
Carl NY
12-03-2005 15:02:09
Davebr. Just for the heck of it, switch the plug wires in the cap before you remove the mag again. See if you get a different result.
