3010 JD hydraulic
STM
12-02-2005 07:17:24
got a 3010 JD has not run ifn 10+ years got it running good.but hydraulic work good but the pump chatter a lot wondering if that is going to hurt the pump to run that why or clear up a little?
donmyeil
12-02-2005 07:24:01
 Re: 3010 JD hydraulic in reply to STM, 12-02-2005 07:17:24
Check the pump drive coupler. the early ones were metal discks and would crack causing the noise you hear. also the new couplers have plastic bushings and will wear and cause a knock as well.
G/MAN
12-02-2005 07:23:01
The pump shouldn't chatter if everything is okay. Make sure the tractor is full of good quality hydraulic oil. Could be some water in it after sitting for several years, or you could be dealing with a plugged up sump screen and filter. I'd highly recommend changing the oil and filter and cleaning/replacing the sump screen. Then see how the pump acts. If it still chatters, you've got some sort of hydraulic leak that is partially starving the main pump for oil and causing it to cavitate. Also check the condition of the pump drive coupling - it could be completely shelled out and creating excessive noise.
Rodney A. Johnson
12-02-2005 11:30:48
 Re: 3010 JD hydraulic in reply to G/MAN, 12-02-2005 07:23:01
What about the stroke control valve??? Might that be the problem?
G/MAN
12-05-2005 07:19:32
 Re: 3010 JD hydraulic in reply to Rodney A. Johnson, 12-02-2005 11:30:48
Possible but not likely if the hydraulics function normally otherwise.
