720\730D PTO How durable ?
JD8020
12-01-2005 16:44:24
How strong is the PTO drive train on a 720/730D tractor? Will it take everything the engine can give it for an extended time? I am looking for someone with experience with high PTO loads for several hours at a time. What are the weak points of the PTO? Thanks Roger
barnrat
12-02-2005 04:45:18
 Re: 720\730D PTO How durable ? in reply to JD8020, 12-01-2005 16:44:24
I have a 730D and an 830. I've used both on the forage blower and on a 718 new holland forage harvester on my 160 acre farm. The only problems I had was they could tear apart universal joints if you let the engine lug to hard.
DW
12-01-2005 22:04:05
Back in '64, a neighbor was grinding ear corn from an outside pile (wet) with an IHC 560 gas. He noticed that the 560 was pulling down, and that irked him so he shovled faster. He killed the 560, so he switched and put his 730D on the grinder. Then he wanted to see if he could kill the 730, instead he twisted the drive shaft off in the grinder. I still chuckle when I think of that incident.
Mel in SW Iowa
12-01-2005 20:30:06
The pto clutch is bullet proof when adjusted properly (they won"t tolerate much slippage), however the pto brake is another story. It cannot be used to stop high inertia machinery (shredder, silage chopper, etc.) without tearing the friction material off of the brake plate. An overrunning clutch must be used in these applications. When adjusted properly, the pto brake will stop the pto shaft every time, just don"t ask it to stop something heavy hooked onto the pto also.
Mel
JD8020
12-02-2005 05:14:20
 Re: 720\730D PTO How durable ? in reply to Mel in SW Iowa, 12-01-2005 20:30:06
Thanks for the replies. It looks like all I have to do is keep it adjusted and have fun. Roger
Island A
12-01-2005 19:01:44
My grandfather used a 720D as a sawmill tractor for at least 15 years, and also to power an irrigation pump. That machine spent more time in PTO gear turning the irrigation pump than pulling a plow or running the mill in my opinion. NO problems with this machine other than the flywheel coming loose, and that is probably due to lack of maintenance.
Dave
95EB
12-01-2005 18:57:31
It'll stand any load the engine can pull, as long as it's in adjustment and nothing is leaking, and it'll live longer than the U-joints of whatever it's turning.
msb
12-01-2005 18:22:56
Deere used a "Pullmore" clutch on those tractors.If kept adjusted they would pull enything the engine was capable of turning.A very tough unit similar to the clutches in a Powershift transmission ,only mechanically,not hydraulically engaged.
msb
12-01-2005 18:25:16
 Re: 720\730D PTO How durable ? in reply to msb, 12-01-2005 18:22:56
So help me.I only clicked once.lol,bob
msb
12-01-2005 18:22:45
msb
12-01-2005 18:22:39
Chuck430C
12-01-2005 16:59:55
The Live PTO on these is like most other equipment. If you have the proper oil in it (10 W), the tranny seals are not leaking at all, and it is adjusted propery, there is nothing slipping that would cause any issues. The problems that come up with the tranny seal leaking is that the gear lube will actually eat away the linings on the disks, you soon run out of adjustment.
If it is correct in every way per the JD manual, I would hook it up to anything the engine will pull at rated RPM, which is around 1,150 RPM under load. If you load it much deeper than that for extended periods, you are only creating future problems.
Hope
dmk
12-01-2005 16:59:49
had 720 on sawmill for years. probably killed the engine 4 or 5 hundred times. no trouble with the tractor, brother just likes to push logs through a little fast.
