41 JD B, which fluids to use????
davidz
11-30-2005 17:06:32
Have my first "new" JD, a 41 B. Am cleaning out old fluids for engine, tran, hydra, and rear axle. Questions are, are there different sumps for the tran, hydraulic, and rear axle? And, which fluids do I use for each???
The JD 4 manual is not very specific. Any help will be appreciated. Thank you in advance for your advice. Davidz
Cliff Martin
12-04-2005 19:07:23
 Re: 41 JD B, which fluids to use???? in reply to davidz, 11-30-2005 17:06:32
I'm going thru the same process with a 1952 JD B and I found alot of valuable info at www.retiredtractors.com Look at most common questions asked " How do I change the oil" Good luck.
ol' guy
11-30-2005 18:28:12
I, too, have a '41 "B", plus other 2-cyl. tractors. For the engine, and Hydraulics I use a quality 10-40 oil. In the transmission/final drive, I use either 90 wt., or 85-140 (preferred). All seem to have worked well. Good luck with your "B".
