Pre ignition
49 JD
11-12-1999 15:13:03
having problem with preignition when at idle have checked timing it seems correct with impulse marks have even used high octane fuel still no success still pings need more ideas
Gerald J.
11-12-1999 16:00:59
 Re: pre ignition in reply to 49 JD, 11-12-1999 15:13:03
Check the timing with a light to see if it changes with engine speed. I suspect the centrifugal advance is sticking advanced. It happens quite a bit with old and worn distributors.
Gerald J.
