450 E
Robert Landers
11-30-2005 09:54:19
Looking at a 450E dozer 84' model. Seems to be in pretty good shape. Any opinions, buyer beware, ect. Thanks
Jonathan in MA
11-30-2005 16:46:19
 Re: 450 E in reply to Robert Landers, 11-30-2005 09:54:19
things to look at/for... water in the engine oil...oil in the coolant... cracked side frames where they bolt to the steering clutch housings.. harsh shifting forward to reverse--(shift f-r without using the clutch pedal-- it shouldnt snap your head back !! ) ... transmission slipping in forward high and low or reverse-- it should spin the tracks into a pile or stall the engine...cracks on the "C " frame of the dozer blade assembly-- specifically at the welds where the left and right sides meet the front cross tube assembly on the blade push-frame... cracks at the towers where the lift cylinders attach... undercarriage condition ...blade face worn beyond or close to the cutting edge bolt holes.. sloppy blade pivot and tilt wear areas...any leaks from final drives...
