Jak, I dont know beans about the LA but I can tell ya this about a Wico C Mag. Okay, if you turn the mag it would indeed affect the timing, BOTH the Start anddddd ddddd Run timing. It really takes a timing light rigged up to see where the run time advance (when impulse wind n trip stops working around 250 RPM) is at, but the Start timing is set in the matter however Glen told ya, so it snaps to fire right at TDC, if too advanced she kicks back, but if too late harder to start. The run time advance (lag angle, how much start time lags the run time) is set in the rear of the mag by loosening the screws and rotating the plate to the left for more run time advance or right for less. Depending on the coupler and how much wear in it and the dogs, straight up is 12 1/2 advance and each mark is 5 degrees, so 2 1/2 to the left is around 25 degrees of advance over the start timing. Okay, if it will run, even if bad, the wires are okay and NOT reversed. Then if she pops loudly and is sluggish like extreme slowwwww ww timing, I would suspect maybe the run time advance setting is way to slowwwww wwww so take a look in the rear if the pointer is like straight up or to the left some as it usually is (2 1/2 to left of straight up). Get it set then set the start timing so it snaPs n fires right at TDC then see what happens. But see what Glen or Duane or the others have to say also. John T
