Hey G-Man 8850 lighting
Tech 7
11-30-2005 06:52:32
I am sure that this PIP predates both of us (1984) with regards to improving the lighting on this tractor... question is after the improvement,RW20608,do the high/low beams react the same as before ie upper rear cab lights go out with the dimmer switch? Also why will all lights continue to work with ALL the lights still come on with the switch? Have you any experience with the lights on these monsters? Thanks, Bob
Tech 7
11-30-2005 13:28:51
 Re: Hey G-Man 8850 lighting in reply to Tech 7, 11-30-2005 06:52:32
Thanks for the reply. I think we have it sorted out the wiring is updated and the original diagrams are not a lot of help.Just have to be pesistent I guess,Thanks again, Bob. Now for that transmission top shaft..... .
G/MAN
11-30-2005 10:11:46
I'm not familiar with that set-up at all. I'd have to look up the program and the wiring diagrams. We don't do much 4wd work at all. I don't know if it applied to the 8450 and 8650, but I know Grandpa's 8450 had some lighting issues way back when, but I think that was just a relay problem.
