J D 530
Don Wood
11-29-2005 17:48:43
? If you have a 530 without s/n tag, what other items,i.e. casting marks mould marks would help nail down at least the year?
Paul_IN
11-29-2005 19:05:47
 Re: J D 530 in reply to Don Wood, 11-29-2005 17:48:43
All of the bigger castings will have a heat date on them. This should be 2 separate little raised portions with numbers cast in. Like a little bitty tag was attached to the casting. One will have up to 3 digits - that is the day of the year. Located close by will be another that has only 1 digit - that will be the last digit of the year. Main case would be a good place to look, also frame will have them, and Powertrol housing, plus lots of others but those would be biggies and easy to locate. Rear wheels have them too, but I'd trust those less since wheels are easy to swap around. If you study your parts catalog and your tractor you may be able to identify some features that changed by serial number breaks to help get a block of numbers.
