JD 2510 will a Model 37 loader work
Wannabe
11-29-2005 17:44:14
I have a 2510 Diesel Hi Crop tractor, can a Model 37 loader be mounted on this tractor with minimum modifications?
Any Comments or suggestions are much appreciated.
Wannabe
11-30-2005 18:16:08
 Re: JD 2510 will a Model 37 loader work in reply to Wannabe, 11-29-2005 17:44:14
My earlier post was incorrect, I have a row crop w/ a wide front, I couldn't understand why a loader wouldn't work on this tractor. Thanks for everyone's advice and help
Do any of ya'll know if a model 37 loader will work on the 2510 row crop w/ the wide front? If so, is it enough loader for moving cedar trees and round bales?
Jim, your advice would be appreciated.
I found one for $500 and the cheapest Model 48 loader I have found is right around $3000.
Thanks again for all of the help.
Handsome Jim
11-30-2005 16:30:47
I think one of the other fellas made good points in talking you out of putting a loader on your 2510, but just in case you get the urge to try it with similar size tractor just keep in mind that the #37 loader was designed to be coupled with a tractor the size of a 820, 1020, or a 1520. We have a 1020 with a #37 mounted on it and sometimes you really have to ease into things for fear of tearing it up. It's defintely a light weight.HJ
bernieinva
11-30-2005 12:39:07
Our farm has gone from B's, 530, 2510, 4030 to a new 6320. I'm 57 years old and of the older models the 2510 is my favorite. We still have it on the farm and going strong.
Paul in WI
11-29-2005 19:30:23
I don't want to be discouraging but mounting a loader on a high crop sounds really dangerous to me. A high crop has a high center of gravity already, a loader with a load would be a pretty dangerous situation in my mind.
Additionally, the bucket of the loader mounted on the high crop would not touch the ground. Other than being an interesting discussion piece, I cannot see any practical value to this combination. Perhaps I am missing something here.
They made 103 of the 2510 Diesel Syncrho High Crops and 29 of the 2510 Diesel Power Shift High Crops. In either case you have a collector item, not something I would put a loader on.
The 2510 and 2520 are wonderful tractors. I suggest you get a regular Row Crop version and put a loader on that. I suggest the Synchro for the loader tractor.
The brochure I have shows a 37 loader, a 47 loader and a 46A loader as fitting a 2510 but I do not know if the mounting brackets were different based on tractor model for the 37 and 47 loaders. I am pretty sure the 46A loader would fit given its mounting system, it is also a better loader by far in my mind.
Paul in WI
Wannabe
11-29-2005 21:44:17
 Re: JD 2510 will a Model 37 loader work in reply to Paul in WI, 11-29-2005 19:30:23
Thanks for the reply, sounds like I have the wrong tractor for what I want to do, the fellow leasing my land is overgrazing the heck out of it and I figured I need to take better care of the grass, etc. Notice my username is wannabe.
I have ~ 240 acres that has a 50 acre hay meadow and the rest is pasture land and I am in the process of removing cedar trees that have taken over my pasture land.
I planned to have a buddy weld up a set of forks to fit on the front of the loader w/ a guard to keep the limbs out of my radiator and hoses so that I can stack the cedars into burn piles (dragging them is getting old).
I also planned to use the tractor to cut and bale the hay for a small cow/calf operation. The loader would be used to feed round bales.
My tractor is in great shape, some folks have told me it might be a collector"s item, mine has the syncro-range transmission, any idea what it may be worth with only 103 being produced?
I am not into collectors and everything I"ve read about the 2510 says that it is a great tractor.
