D owners, or other standard-tread owners...
G/MAN
11-29-2005 07:22:30
You guys with standard-tread tractors from wheat country should check something on your iron. donwisc's post about his "D" made me thing of this. A good friend of mine has a very nice and straight original styled "D". One day when another gentleman came to look at a 6030 he was selling, the guy mentioned that he had seen "D"s that had been in so much wheat stubble that the underside of the front axle was "serrated" with grooves from rubbing against the stubble. We checked Tom's "D" right then, and sure enough, the front axle was grooved. I wonder how many miles of wheat stubble it takes to do that.
RalphinWI
11-29-2005 19:15:43
 Re: D owners, or other standard-tread owners... in reply to G/MAN, 11-29-2005 07:22:30
Are you talking about worn area equal to the drill spacing, or a genereal random serration of the underside of the front axle? In the former case I suspect it requires planting wheat with a press drill behind a moldboard plow.
G/MAN
11-30-2005 10:14:29
 Re: D owners, or other standard-tread owners... in reply to RalphinWI, 11-29-2005 19:15:43
Just general seration - much more closely spaced than the drill spacing.
David from Kansa
11-29-2005 10:52:33
About every D I've seen around here shows grooves in the bottom of the front axle. Both of the D's we had were well grooved. I've shown this to some people at tractor shows and they find it hard to believe it is from the wheat stubble (and a few weeds, I'm sure).
jas
11-29-2005 09:24:01
Oh yes. My 29 has it but I didn't notice it on the 48. I know of some others in the area that have it too.
Spoker
11-29-2005 07:57:22
I have checked mine and it had no signs of the grooves. This 29 D that I have I do not think it was used in the Wheat fields. As bad of shape the tractor was in leads me to believe it was used in some road construction jobs. It had every thing imagenable worn out. Even the drive chains rollers were broken to the point that most of the links had only the pins holding them together. The reverse bushing was so thin that you could see threw the bushing (well it had a very slight touch of bronze color to the gear). The Planitary gear bushings were gone, that the spider gears would clear out of the planitary gear. The shifting forks were worn to an almost paper thin size. I have spent almost $6,000 and no labor counted, to get this D back into shape. So far it has a new block, sheet metal, new DLTX 3 carb, pistons, rings, new valves, valve seats, New Wico Mag. And many other new parts. It is going to have the right rear axle replaced now, the preload splines are worn out and you can not set the preload on the axle bearing. I have to much in it to stop now, and I know it will not bring what I have in it. I don"t care I still LOVE the old D.
