2955 no Lo
Plant Doctor
11-29-2005 05:13:26
My neighbor brought his 2955 over and put it in my shop for our cold winter days project. We get a lot of farming done in my shop while doing these projects!! The "Lo" in the trans is not working. While I am waiting for the shop manual is there anything anyone can tell me about this model tractor. Has this "Lo" been a problem with this model. Where would you start to diagnose this problem? Anything else I should be looking for while I have this in the shop? The longer I keep this tractor in my shop, the more world problems get solved!!! I really should charge a head tax to get in shop door, I would never have to work again! Thanks in advance.
R. John Johnson
11-29-2005 05:52:44
 Re: 2955 no Lo in reply to Plant Doctor, 11-29-2005 05:13:26
That depends on what you mean by "LO". Do you mean LO range or the hydraulic HI/LO? If it's the hydraulic, some one else will have to help.
A couple of years ago I had a bearing go in the transmission of our 2755. I had it fixed at my cousin's shop. The local Deere dealer told us to check the hollow shaft that goes from the shifter rods on the cab into the transmission itself. There is a spot on the shaft that is milled away to clear a component in the transmission, and is prone to crack at this spot. If it breaks the tractor will either be stuck in LO, Reverse or unalbe to shift into either of these. Mine was cracked almost all the way through, so I saved a major repair by changing it while we fixed the bearing.
Hope this helps.
John
