5310 3rd remote
amo
11-28-2005 17:04:46
i have a 5310 with front end loader and a 3rd remote to use with harrow etc. i did not use this remote while under warranty. when i tried to use it it would not operate. the dealer said tough luck out of warranty. is their an easy fix to this or not. now to use a harrow i unhook the one hose on loader . thanks in advance
Joe M(GA)
11-28-2005 17:28:41
 Re: 5310 3rd remote in reply to amo, 11-28-2005 17:04:46
Does not operate? What doesn't?,does the lever move and nothing happens? Is the lever rusted in place? A 5310 isn't a tractor that would still be anywhere near being under warranty anymore, my bet is a linkage that has rusted in place from lack of use.Have someone wiggle the lever while you look under the platform, you should be able to see what is or isn't happening
amoo
11-29-2005 04:46:01
 Re: 5310 3rd remote in reply to Joe M(GA), 11-28-2005 17:28:41
the lever moves and every thing seems to work but no fluid goes through the valve, dealer said a new valve was needed, it is the inside valve on group of 3 mounted side by side. thanks
