49' B
HoboBob
11-28-2005 13:25:56
Our 49 B's govoner, throttal has froze up over last cold night. I will start and slowly unthow itself but takes a while to do so. Any tips on how to prevent this is greatly appreciated.
HoboBob
j summers
11-29-2005 14:30:48
 Re: 49' B in reply to HoboBob, 11-28-2005 13:25:56
lee b is a very smart person i also own a little b and i found out the hard way that you should run a good brand of the right weight of oil in it.
Jason Z in MO
11-29-2005 08:56:20
Are you sure it"s the governor and not the throttle shaft at the carb?
Lee B
11-28-2005 21:42:12
If it has a fan shaft ventilator pump, get that working again. The governor case is full of condensation. Changing oil more often might help some but it's doubtful at this time of year. Condensation builds up when the engine is not run at working temperatures long enough, only solution for that is not to run it at all if you can't/won't run it long enough to dry it out each time it's run. It's a cumulative thing, and you've been working at it for quite some time now. It's too cold this time of year to get much relief unless the ventilator pump (if so equipped)starts working and you put a real load on the tractor for several hours to get the oil good and hot.
