4020D Block Heater
MaverickM23
11-28-2005 07:21:16
We had a John Deere block heater installed on our 4020 about 3 years ago. This weekend i plugged it in overnite and in the morning found that it wasnt working. I made sure the cord had power which it did but the heater never heats up. Any ideas?
R. John Johnson
11-28-2005 11:13:32
 Re: 4020D Block Heater in reply to MaverickM23, 11-28-2005 07:21:16
Jason is right. If it worked before, but doesn't work now, you have an open circuit. Broken wires in the short cord is the most common problem. If not secured properly, the cord swings back and forth when the tractor is in motion. This eventually breaks the wires inside the cord.
Look carefully at the heater. There should be a cover held in place with a single screw. NOT the fasteners that hold the element in the tank. Take the cover off and start checking.
John
Jason Z in MO
11-28-2005 08:34:42
I have one in a box at home but I don't know if they are thermostatically controlled. Regardless, if you know how to use an ohm meter you should be able to see only a couple of ohms at the plug. If not, the short cord is bad, heating element or thermostat if it has one.
Remove the cover, I think its a single phillips screw in the center. When inside you should be able to check the individual components.
4010guy
11-28-2005 07:45:20
how do u put a block heater on a 4020(no frost plug)was it a tank heater if it was it mite be bad thurmested.in a pinch u can hot wire it out the bottom of it(just be very careful)
MaverickM23
11-28-2005 08:35:38
 Re: 4020D Block Heater in reply to 4010guy, 11-28-2005 07:45:20
Its a coolant heater from John Deere that goes on the side of the tractor. It works great except for now it wont heat up.
4010guy
11-28-2005 08:55:59
 Re: 4020D Block Heater in reply to MaverickM23, 11-28-2005 08:35:38
gess i still dont understand is it one of those magneteg heaters OR doz it tap into the cooling line(forgive me as i am a little dents sometimes)ha I do know some heaters onely last a while and then u just gotta buy another
Hayfarmer
11-29-2005 07:19:18
 Re: 4020D Block Heater in reply to 4010guy, 11-28-2005 08:55:59
JD block heater goes in the one of the holes plugged by pipe plugs, hex inset type, on the right side of the tractor, usually one of the front ones. You take the plug out and put in heater, usually you have to heat the plugs because they are put in with loctite.
