420 STARTER QUESTION
HAL
11-28-2005 07:07:29
I am trying to figure out my 420 starter, it seems the switch mount and copper stud are to far forward from what I see in the repair manual,they are all more to the rear by the brush inspection holes, I was at the show in Cullman Al this weekend and looked at all the 40s and 420s and found one other that had the same problem, they had rigged the starter rod so it pushed instead of pulled, anyone else ran into this i had the starter rebuilt and put in a new armature so I hate to go looking for another starter but I may need to thanks Hal
Wayne in Tn.
11-28-2005 08:29:56
 Re: 420 STARTER QUESTION in reply to HAL, 11-28-2005 07:07:29
Hal, I have never had that problem, so I cannot give much advice on how to rig it "wrong". But maybe a couple of tips on the "right" way. First make sure you have the right starter switch. I have always got the correct one from Deere or Carquest. Seems that Carquest is reasonable priced. Next, the screw holes in the starter housing should position the switch flush beside the brush cover band, even touching it.
So I can only see two problems, either the wrong switch or the wrong starter housing. Maybe someone has put the nose on the wrong housing? Also make sure you have the little lever mounted on the switch correctly.
HAL
11-28-2005 11:11:19
 Re: 420 STARTER QUESTION in reply to Wayne in Tn., 11-28-2005 08:29:56
Wayne I have noticed on others like you said the switch mounts very close to the band that covers the brushes but mine is completely on the other end, maybe if I can just come up with a housing my armature will work?
HAL
11-28-2005 07:32:34
I would have to lengthen the rod and make it push instead of pull, if you simply turn the switch around the inner workings of the switch arent close enough to make contact, even if that worked the rod would need extended, I know how to "rig" it, I just hate to because I took no other short cuts in the project and didnt want to start now. I figured Wayne in Tn or someone had ran into this before..... ...
Hayfarmer
11-28-2005 07:17:16
The only problem I see with Push instead f Pull would be a chance of pushing it accidently. Maybe someone at some point changed the starter on this tractor. The new ones through NAPA or someone may not match perfectly. Can you just use a longer rod? I got a new bendex from NAPA a couple years ago, they had trouble matching it, the one I got never worked that great. May be the same with your starter, it is "almost" right.
