3020 gas (Generator)
B. Jones
11-28-2005 06:15:36
Does anyone know if a 3020 gas generator is an A circuit or a B circuit. The generator light is on. Thanks.
B. Jones
11-28-2005 07:48:20
 Re: 3020 gas (Generator) in reply to B. Jones, 11-28-2005 06:15:36
Dear John,
Thank you for your quick response. I'm getting ready to go look at the tractor right now and your information will make things much easier for me. Again thanks. B. Jones
John T
11-28-2005 07:28:58
As far as I know all those Delco gennys ued on Deeres and most other tractors are all A circuits, the only B circuits Im aware of are on a few of the Fords. Therefore, if when running you dead ground the gennys Field post n she starts to charge its either a bad VR or the VR isnt well grounded or the wires open from the gennys Field post to FLD on the VR. If still no charge even with the Field grounded, leave it so n by pass jump the VR"s BAT and GEN together to see if she charges then, which would indicate a bad cutout relay inside the VR. You need a tight belt and a good genny ground also.
John T
John T
