720 JOHN DEERE
DEEREPULLER
11-12-1999 08:56:15
I had my 720 John Deere at a tractor pull and I was pulling in second gear. I got down to the 190
foot line and it slipped out of gear and after that it would not go in reverse or second gear but I drove it out in fourth but now second and reverse seem to work fine without a load.
Chuck
11-12-1999 09:34:49
 Re: 720 JOHN DEERE in reply to DEEREPULLER, 11-12-1999 08:56:15
sounds like you have some major problems. First either your bearings on countershaft, driving shaft, or your spline to gear is worn to the point that it is putting side pressure on the gear causing it to slam out under a hard pull, your locker is also worn and not holding in place..if you keep this up you'll be breaking something big time. Time for dismantlement and correction.
