1942 H Trasmission, No reverse, 2nd Locks it up
JDVan
10-26-2003 20:08:24
My 1942 H transmission went belly up today. 1st and 3rd work fine. 2nd gear postion locks up the transmission, Reverse no longer works. Shifter firmly held in place with new components installed a couple years ago. No problems for 2 years then this. Help???
Clooney
10-27-2003 03:18:36
 Re: 1942 H Trasmission, No reverse, 2nd Locks it u in reply to JDVan, 10-26-2003 20:08:24
JDVan, it sure sounds like it's stuck in first. Probably due to either a broken shift fork or the 1st/R shifter fork has not returned to neutral & the shift lever in now behind it & won't move into the center slot.
~The good news is there isn't much to that "H" shifter so there are very few things it can be.
~It would be a good idea to look at the left end of the shift rail on the little cover on the L/H side of the case to see if either the limiting bolt or set screw has come loose.
~If the set screw & adjusting screw are still tight you will have to pull the shifter cover to see if you can find the problem [it shouldn't be hard to find].
[email protected]
JDVan
10-27-2003 07:16:36
 Re: Re: 1942 H Trasmission, No reverse, 2nd Locks in reply to Clooney , 10-27-2003 03:18:36
Thanks Clooney for the tip. I'll check that. However, the symptoms are slightly different. The 1st and 3rd gear positions work fine. Even after it locks up in the 2nd gear position. No reverse at all. it would be nice if it was simple as the set screw coming loose but I'm afraid it's going to be a broken or worn shifter. No unusual noise prior to occurence. It was a bit of a surprise. Thanks again.
Dan in Pa
10-29-2003 17:41:42
 Re: Re: Re: 1942 H Trasmission, No reverse, 2nd Lo in reply to JDVan, 10-27-2003 07:16:36
I had the same problem with my 1940 H, only I had 1st and rev ,lockup in second ,no third. Turned out to be a broken fork .
