DLTX-67 stem repair update and brazing question.
Kurt_JDB
11-27-2005 16:09:58
First of all, thanks to all of you for the excellent suggestions on how to repair a broken carb stem. I was able to braze the cut-off end of a spark plug onto the stem. Considering that I have very little experience with brazing, I consider this little short of amazing. Unfortunaly, the little oxy/map gas torch I was using ran out of oxygen before I was done. This resulted in a couple of areas where the bond was not completed.
Should I cut it back off and start over? Or can I reheat the carb and continue with what was started?
Or can I fill the areas not bonded with something like JB Weld?
New threads seem very well attached and well aligned.
I have one other question, the break in the stem happened at the hole drilled through the side of the stem above the threads. Can any one tell me what size drill to use to rebore this hole?
Thanks,
Kurt
Mike M
11-28-2005 16:42:11
 Re: DLTX-67 stem repair update and brazing questio in reply to Kurt_JDB, 11-27-2005 16:09:58
You might be thinking about a hole with a plug just opposite where the fuel load needle goes into. If yours has this than it was just to get into to reach across and drill the fuel inlet passage by the needle. One up a little and off to the side has that secret passage they talk about this is for the idle passage.
Kurt_JDB
11-28-2005 18:45:31
 Re: DLTX-67 stem repair update and brazing questio in reply to Mike M, 11-28-2005 16:42:11
Mike,
From what you described, it sounds like there is no reason to redrill this hole, as it was plugged. In other words, there was no open hole at the bottom of the stem just above the threads.
Thanks,
Kurt
Mike M
11-30-2005 03:52:32
 Re: DLTX-67 stem repair update and brazing questio in reply to Kurt_JDB, 11-28-2005 18:45:31
Just make sure fuel can get in by the load needle. And check out all the idle passages for any blockage also.
P Browning
11-28-2005 12:28:25
Kurt -- I assume you are refering to the short horizontal hole at the end of which goes a drill plug. I think I know the size, but rather than "think" I ask that you give Robert a call at Robert's Carb (712) 262-5311. He knows! (PatB)
Kurt_JDB
11-28-2005 16:03:12
 Re: DLTX-67 stem repair update and brazing questio in reply to P Browning, 11-28-2005 12:28:25
Pat,
I was told the there was a hole drilled into the stem immediatly above the threads on a DLTX 67 carb that was left open as a hole. This area is right where the stem broke, so I cannot tell exactly where the hole is, or what size. I am NOT talking about the other short horizontal passage which has a drill plug in it about half way up the stem.
Kurt
P Browning
11-28-2005 18:34:40
 Re: DLTX-67 stem repair update and brazing questio in reply to Kurt_JDB, 11-28-2005 16:03:12
Kurt -- This is where creative use of a digital camera can be a super help -- if you have one or access to one. Stick some little pointers on the specific region you have a question with -- also a unique picture number for each picture that shows up in the picture, etc. And when you have the pictures set, prepare a set of narrative & questions to go with them -- build up an e-mail, and send it off to with a note that you will call him about the message. I can assure you -- answers will come! (PatB)
Marty Z
11-27-2005 22:35:28
Can"t help you on the drill size but I have done a bunch of brazing. I would leave the added part that you brazed already. Clean it up on a wire wheel then heat it again. Clamp it in place if you can ,, so it doesnt get off center. Get it just about as red hot as you can and melt some more rod on to it. My best brazing jobs are applied to the metal at the point where it is about to melt/weld. If you get some brass on the threads it should chase off with a die.
Marty Z
